pacbrake-holy crap!!!!!!!!!!!
Old Feb 23, 2009 | 07:22 PM
u.s mma's Avatar
well I finally got power to the main harness, ran a dual fuse block and got juice like that. I got a model for a 24 valve, my god its incredible, way better than my dads bd unit on his 01. It stays steady on in 4th till below 30mph, I figured it cut off at 35 or so. The thing took me days to get right, Im glad it finally works and so well at that.
Old Feb 23, 2009 | 07:28 PM
peobryant's Avatar
I'm glad you like it. Now go and rub it in your dad's face.
Old Feb 23, 2009 | 07:29 PM
Billut's Avatar
What Pacbrake did you get? Remote or turbo mount? Vacuum or air actuated? What BD does your dad have? Just a few details to compare apples to oranges, know what I mean?
Old Feb 23, 2009 | 08:12 PM
u.s mma's Avatar
yah, your right man. I got the turbo mount,24vavle model, the outlet is like 2 3/4". its vacuum actuated, I put in the shifter thumb switch, which is sweet, real nice quality. My dads brake is a bd, turbo mount, vacuum jobber. he just has a toggle under the steering column. It works well, no doubt, Ive had some good loads on nasty windy grades and it is nice. By seat of the pants, the pac seems to really hold back a lot harder, and in lower rpms. (although I don't have a tac, so that might be slander) below 1900 rpms the bd cuts on and off, Im pretty sure in 4th gear, doing 28 Im well below 1900, and the pac just held solid.
Old Feb 23, 2009 | 08:31 PM
DennyT's Avatar
NICE!! Ive been looking into this. Just got back from Red River NM in a 3rd gen with a factory exhaust brake.............worked AWESOME. Im hooked.......
Old Feb 23, 2009 | 11:24 PM
Alwaysworking's Avatar
alwaysonDTR
did you install the heavy duty valve springs?
Old Feb 24, 2009 | 12:00 AM
u.s mma's Avatar
yes, just the exhaust springs.
Old Feb 24, 2009 | 09:04 AM
Billut's Avatar
Sounds like a big difference if BD seems to cut off around 1900 rpm and the Pac still holds...
Is your dad's truck with 60lbs valve springs too?
You mentioned the outlet on the Pac is 2 3/4": is it clamp-on? How about on the inlet: what exhaust housing do you have?
You have a 1990 truck so you have hi-beams on the floor, right? Iwas thinking of using a similar switch from an older truck to use on my 92 for exhaust brake on/off, and keep the shifter mount for Gear Vendors OD.
Old Feb 24, 2009 | 09:15 AM
archer39's Avatar
you know you would need a lock-up torque converter to take advantage of the exhaust brake right?
Old Feb 24, 2009 | 09:18 AM
Billut's Avatar
yes I do, I really should update my sig., as I'm fixing to swap the A518 to a NV4500. With that in, the exhaust brake will be a better application. Good point!
Old Feb 24, 2009 | 09:19 AM
archer39's Avatar
ok, just checking
Old Feb 24, 2009 | 10:15 AM
u.s mma's Avatar
As far as the bd cutting on and off, it does have 30k on it, and my old man is a drive it and forget about it kinda guy, so the thing might need some lube, maybe the butterfly is sticking, I don't know, I m not trying to bad mouth the bd, it does work well. the pac I bought does clamp on, Ive got the18.5 i believe, I dont have the floor high beam, I wish I did. Im going into town in a bit, so I will post again driving results in town. One thing about the pac is the price, a bit cheaper than the bd.
Old Feb 24, 2009 | 11:46 AM
Ace's Avatar
Ace
I use the throttle switch so it's on all the time. Except of course, when the throttle is not closed. It's adjusted closely enough so I can modulate the exhaust brake with the accelerator pedal on long downgrades without adding fuel:
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_172.jpg
Old Feb 24, 2009 | 12:18 PM
apwatson50's Avatar
I had a similar setup on mine when I first installed it, until I wen to make a shift and let off the throttle too far, engaged the brake and blew the exhaust pipe apart. ended up with an open down pipe. haha Had to slide under and slip it back together.
Then, this was an issue with my mounting etc.., the linkage wouldn't always come back and engage the brake, which sucked going down hills.
So now I just have a switch mounted on my shifter, and thats it, I either turn it on, or off. no linkage to worry about, as long as I have air and power the brake engages when I want every time.
Old Feb 24, 2009 | 06:38 PM
bullfrog5.9's Avatar
whats the noise like
do u hav a link for the one u got
