P-pump cruise control?
Old Feb 10, 2012 | 07:17 PM
Mopar1darrell's Avatar
10 Year Member
I have a 1st gen cruise control unit(for my never before equipped w cruise 92) and a 215 p pump swapped in. I have never owned a ve pump or a second gen so im putting together a blind puzzle. The throttle travel on the pump looks to be too long travel to work with the stock style cruise unit. So a second gen one might work. Just seeing if anyone already knew all about it. Thanks
Old Feb 29, 2012 | 11:45 AM
10 Year Member
Anyone? Not real important but figure someone already knows. Thanks
Old Feb 29, 2012 | 12:04 PM
dB Zac's Avatar
the cruise control cable is actuated by a pin on the bell crank normally mounted right below the intake horn (ignore the spring, it normally does not go there)
so as you can see, if you have your peddle ratio correct, you should be able to make the cruise cable work also
Old Feb 29, 2012 | 12:16 PM
bobva's Avatar
If I'm reading this correctly.
You have a P-7100 IP on a 1st gen truck and your trying C.C. it.?????
I would think the 2nd gen C.C unit would bolt right in. Then its just wiring it in. ICBW
Old Feb 29, 2012 | 05:03 PM
10 Year Member
Im gonna go to the parts store and see if they are anything similar as far as wiring goes. Thanks
Old Feb 29, 2012 | 06:01 PM
BC847's Avatar
1st Generation Admin
Actually, FYI: pending the truck, there is a spring that goes there (mine has one there stock/OEM).
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
robox
Oct 17, 2005 03:42 AM
christinyou
Mar 11, 2003 11:08 AM
TexasDiesel
Dec 27, 2002 10:47 AM
