only runs when floored
Old Jan 10, 2014 | 08:20 PM
91dodgecummns's Avatar
hi guys got a big problem first off i got a 91 dodge diesel and decided to try and turn up the pump first problem after turning up pump was had no power started up idled fine but had no power so read about the little pin thing that rides on the slope of fuel pin gets stuck amd it was stuck so i took the throttle bracket apart to get to bolt to free up that pin well got it all back together now it wont start unless floored if i let off the pedal it dies and when its floored its at idle speeds idk what to do at this point if anybody can help i greatly aprreiciate tganks
Old Jan 10, 2014 | 09:48 PM
fatt's Avatar
You need to take the throttle bracket back off and re index it on the throttle shaft that sticks out of the pump top. I can't think of which way it needs to go right now, but do it so that when in the new position it acts like you are pressing on the accelerator. Go one spline at a time until it's right.
Old Jan 10, 2014 | 10:02 PM
ya i finally figured that out been workin on it for the lasr hour but finally got it goin. had to re adjust everything its been a pain in the butt but ive learned how everything works now. still doesnt quit feel the same as before but it drivin so im satisfied with that for now
Old Jan 10, 2014 | 11:37 PM
Jim Lane's Avatar
The VE pump is really simple once you understand how it works.
A word of caution when working on you pump, especially linkages and the governor.
Always have a way to snuff out your engine in the event of a runaway.
It can turn your engine into a pile of scrapmetal instantly.
Old Jan 11, 2014 | 10:53 AM
simplysmn's Avatar
when working on the pump Take Pictures of the indexing on the shaft that way you know how you started work's every time
ironmike
Feb 24, 2014 12:15 PM
delagem
Oct 23, 2012 09:55 PM
notpowerSTROKIN
42
Nov 10, 2007 09:02 AM
wilderness
Sep 17, 2006 08:23 PM
SilverRam01
Jul 31, 2005 06:36 PM
