oil smells like diesel
Old Sep 13, 2012 | 07:52 PM
bannerd's Avatar
Hey all, tomorrow I maybe going on a two hour ride I notice tonight that my oil light came on and I checked the oil it was fine. When I smelt it.. I could smell a hint of diesel in it. I haven't changed the oil in awhile and it's on my to do list. Is this normal?
Old Sep 13, 2012 | 08:20 PM
j_martin's Avatar
NO
Fuel oil isn't a good enough lubricant for rod bearings.
Don't drive it.
Change the oil
Find out where it came from, likely lift pump or IP front seal.
Old Sep 13, 2012 | 08:41 PM
1STGENFARMBOY's Avatar
In my best Barney Fife voice, ( of coarse it does what do you think they run off of coal ).
i say change it before you go, and keep an eye on the level to make shure fuel is not getting in the crank case, via the original lift pump diaphram.
Darwin
Old Sep 13, 2012 | 08:46 PM
man it would help if i read the other answers before posting.......EH PACHA......
Old Sep 14, 2012 | 05:51 AM
bannerd's Avatar
Going to do a quick change, it's 11quart of 15-40 correct?
Edit, nevermind found a sticky with fluid levels, looks like 12 quarts
Old Sep 14, 2012 | 06:49 AM
dzl_damon's Avatar
Yeah, just 3 gallons of your favorite 15w40 such a Rotella or Delavac, etc.
It will cost about $45 or so from wal mart. I would check your lift pump first for the leak since it's the easiest to get to and cheapest. I think a stock lift pump can be found for about $40 if you look around. Some places charge far more for no good reason.
injection pump front seal is more involved and requires the removal of the ip. However, if you are using the stock lift pump, you SHOULDN'T have a problem with the front seal on the IP. usually too much pressure to the IP is what causes seal issues there.
Old Sep 14, 2012 | 06:59 AM
bannerd's Avatar
Yeah, I think the oil is really old. I haven't changed it when I bought it from the old gentleman last year. I don't drive far to work (three minutes) so I don't put a lot of miles on it. I rebuilt my pump a few months ago and put a new seal in. Is the lift pump that manual pump before the filter?
Old Sep 14, 2012 | 07:15 AM
Yes, 2 lines and 2 bolts and it's off, but i would drive it before i pulled anything off.
if i use a little paranoia i can smell diesel in my fuel also, so it mite just be sooty enough to smell like fuel.
Dar
Old Sep 14, 2012 | 07:28 AM
gyman98's Avatar
Some fuel in oil is normal but even without changing oil for a year you shouldn't be able to smell it
Old Sep 14, 2012 | 11:55 AM
maybe368's Avatar
[QUOTE=dzl_damon;3132263]It will cost about $45 or so from wal mart.[QUOTE]
I wish, I run 15-50 mobil one, much closer to 200 bucks...Mark
Old Sep 25, 2012 | 08:22 AM
bannerd's Avatar
Well I changed my oil, Rotella T for about $30 from TSC. Put a wix filter on her. Ran about 400 miles.. check the oil and it was clean as can be. Now my oil pressure light keeps coming on in the cab.. the guage will go way past low and and the oil light comes on. If I put it in gear it climbs back up to full pressure. Where is the sensor on the block, I'm thinking that I might need a new on.
Old Sep 25, 2012 | 12:48 PM
j_martin's Avatar
I'm thinking you fried all your bearings the first go round. Keep running it till it ventilates the block.
Old Sep 25, 2012 | 12:56 PM
bannerd's Avatar
Ok.
Old Sep 25, 2012 | 04:55 PM
Gunnar1971's Avatar
I am having sort of the same issue.
Truck and oil pressure are fine until the truck runs for about 45 minutes, then the oil pressure gets low and causes the oil light to flicker, I have also noticed that the idle has dropped just a bit once the truck warms up.
I was thinking of bumping the idle a tad and possibly installing an oil cooler, but am unsure if this will fix the problem.
Old Sep 25, 2012 | 06:40 PM
patdaly's Avatar
Should be the same as in the second gen 12V, look right behind the PS pump, about midway of the pump up and down.
I would get a manual gauge on it right away though, no sense in ventilating a perfectly good block.
