Oil PSI Question ???
Old Sep 28, 2007 | 03:19 PM
pred's Avatar
For those of you who are running an oil pressure gauge, I have a question....
With a cold engine I run 40 psi @ 600 rpm, and 80 while driving softly while letting warm up, I know that the blow off is somewhere in the 65 lb range,,
Now for the Q
After the enging is run for many highway miles, and quite warm,,, I idle at 550 rpm and hold 20 lbs no matter how hot, and 40-45 lbs when above 1500 rpm or so, I will keep the 40-45 lbs no matter how high the rpms,,, Does this seem normal?
The fsm says no lower that 10 psi at idle, and I think 20 at rev limit, so I am above those #s,,, But am interested in what the real world says!
Thank you for any imput!
Peter.
Old Sep 28, 2007 | 06:02 PM
badram's Avatar
Hey Pred , I dont have a tach , but I put a mech. guage in when the factory sender went and mine with 200.000 miles cold 68-70psi , 60psi at 55 warm ,45psi cold idle and 20psi after 20 min of runtime at idle ,hope that helps.
Old Sep 29, 2007 | 12:05 PM
bgilbert's Avatar
Now for the Q
Peter.
You numbers sound fine. I see about what you are seeing.
38 Cigarette
16
Aug 28, 2015 11:27 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
