odometer works, but speedo stopped working
A few years ago I replace the 2 little plastic gears in the odometer, and got the odometer working again. Now, the odometer still works fine while the speedometer quit working. It went out intermittently for a few months until it finally won't work at all anymore. Again, the odometer still works fine. I cleaned the contacts on the connection on the transmission, but I was under the impression that they were ok already since the odometer hasn't stopped working. Any ideas? Thanks. -Jeff
Mine did the same thing, the speedometer worked for awhile after then just finally quit but if I hit a bump it would work again for awhile.
Pretty sure it is a loose connection on the speedo head, I need to pull the cluster and check them carefully.
Going to figure out a way to supply a pulse to the head to see it work out of the truck before I have it all back together.
I have been using my GPS for a speedometer.
Jim
Jim
Jim
Jim
For a pulse, 555 is your friend.
I used to use a filament transformer capacitors and a voltage divider to calibrate analog tachometers against the 60hz.
Any update to this? I am having the same issue. My odo is dead on, but my speedo has been going out. Ive been using my GPS for speed, but I just moved to the UK and in order for my truck to pass MOT, I have to have a fully functional speedo....dont ask me why they wont allow the use of GPS
Sleigher
May 4, 2017 02:12 PM
CaledoniaOutlaw
Nov 26, 2012 11:52 PM
yarddog
Mar 28, 2009 06:01 PM
