NOW what!
Old Apr 9, 2009 | 01:22 AM
mopar2ya's Avatar
NOW what!
So I ended up replacing my steering box and shaft a couple days ago. I get in and all is good. I go 50 ft and no power steering unless you rev it to 2000 rpm. Fuild is where its supposed to be, so I put a new pump on today and it works like a champ. So I back it out for a test drive and now I have NO power brake assist!!!!
I didnt look at it at that point. I suppose I will pull the hose on the vacuum pump and see if its sucking, if so Its got to be a bad hose or brake booster.
So heres the question. If there is NO vacuum from the pump, whats typically the problem associated with that?
BTW, gotta do ball joints, I got the death wobble back again... Any tricks/tips?
Old Apr 9, 2009 | 01:25 AM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
i dont do hydraulics but could have an air pocket in your line and it be causing your pump to lose prime until 2000
Old Apr 9, 2009 | 01:28 AM
oh **** i only red the top part of your post Duh
Old Apr 9, 2009 | 06:42 AM
The vacuum pump is really simple and they almost never fail. I would bet that your problem is a leaky hose (or one that fell off) or a bad booster.
Old Apr 9, 2009 | 03:19 PM
mopar2ya's Avatar
Found it. The hose broke where it hooks into the cruise...
moparmatt
May 1, 2015 08:49 AM
Shorts
Jun 29, 2013 09:23 PM
95ram
Jul 28, 2010 02:17 PM
ramlovingvet
Mar 22, 2003 08:32 PM
cfm3110
Mar 18, 2003 10:54 AM
