not running
Originally Posted by Buffman88
i was pulling out of the drive way and the thing just died, i have plenty of fuel but theres none in the line? can anybody help me out
Do u mean u have fuel up to the pump, an none in the injector lines?? Or a full tank an none to the filter? If theres none in the injectors lines check your fuel shut off and the wire ends pluging in to it Could be stuck shut. If theres none to the filter sounds like the lift pump. Let us know how it turns out.
Originally Posted by timb
Sounds to me like the wire came off of the shut off solenoid also.
Carl
Originally Posted by carl20320
This, and running out of fuel, are the only reasons I have ever seen a 1st gen just die. Being it was probably accompanied by the bump while backing out of the drive, I suspect your wire either came off or shorted to something else. The plug that is mounted to the wire is pretty crappy. You might want to take a pair of needle nose and crimp it closed just a little.
Carl
Carl
zachv
Jan 24, 2005 10:46 PM
donwon9999
Sep 24, 2004 08:16 PM
