No AC
No AC
Well the title says it all. I had it two years ago and never really used it. Now with temps in the 98-102F it sure would be nice. Took it to a shop and they said my compressor is no good because I have a leak and all the gas ran out. Would that kill my compressor? I found a seal kit at napa an was going to seal it up and test it with propane as a refrigerant.
My brotherinlaw the mechanic said a seal self installed never holds. I wound up buying a complete kit from Buyautoparts.com(never again, but thats a different story) Anyway my has been working good for 3 years w/134A Good luck
the good old days.ask me about the Japanese machine repair guy that wanded a part reworked with a .0001 tolerance on an old engine lathe(By hand).
You can buy it pre-mixed in several brands.
One 8 0z can of mountain stove fuel (ISO-heat) and 12 OZ of ColeMan propane is just about right.
For most cars you can dump in a can of stove fuel, then 12 OZ of propane and it'll be just about right.
I pre-mix it into a used 30 pounder. You can't bleed off gas if you overcharge because propane will leave and the isobutane remains.
The oil for R12 works with it just fine.
The recipe for C-12 is 79% propane, 21% isobutane. (not butane)
Some googling shows that it only requires 35% HC-12A of the R-12 amount. It's supposed to be compatible with the oils used in both R-12 and R134a systems.
BUT, it's flamable.
I've not been very happy with my conversion because it doesn't cool very well with R-134a so I'm thinking about converting.
Edwin
BUT, it's flamable.
Edwin
I know nothing of ACs but have "heard" that if you don't use them regularly the seals dry out?
I'm like you Bannerd, I seldom use mine. Only when the wife is riding or I have a dress shirt on and need to not be sweaty (very seldom occurance in the truck). Last time I used it (with the wife riding) on a road trip and it would blow cold then not then cold then not...
Almighty then, I'll have to save some money and buy a kit. Tough these days when the wife isn't working because baby sitters want $250 a week per kid(we have two).
I found a few kits between 200-300 dollars which isn't too bad. The mechanic wanted to remove the R134a (The fittings tell him my system was converted at some point from R12). That's $40 for removal and disposal. The rest was $700 for parts and labour.. which it can't be that hard.
Harbour freight sells a manifold gauge set for A/C for $50 and I found a kit for on ebay for $198. I tested my compressor last night and the clutch engages.. Should I just get seals and hope for the best? Napa has seals for $5 and they're tabbed. The guy I talked to said just mark the seals to the blocks that way you can get the seal right by moving the tab in between marks. Another option is I could take the hoses to my machine shop and grout a place for o-ring if this thing leaks or is known too.
So what is the deal, I assume I need lubricating oil in this system? Or do I need to get the old oil out?
