New EDGE turbo?
Old May 10, 2006 | 02:43 PM
trev1981's Avatar
New EDGE turbo?
Has anyone used the new EDGE turbo on there 1st gen or know of anyone that has?
Old May 10, 2006 | 10:28 PM
Jethrro's Avatar
I read a article in the Diesel Power Mag and was under the impression that it was for the newer motors. It seems like all the good parts are made for the 1994 to current Cummins. There were some good points but I felt you could get something compareable from High tech turbo and less $$ too. Jethrro
Old May 11, 2006 | 03:11 PM
chuxtruk's Avatar
Most every turbo even on a second gen 12 & 24 valve engine will fit our trucks. The HX-35 is a direct replacement for our stock lag-masters and if I remember correctly anything up to a 98 will work. I didn't know that either until I started looking around for a replacement housing for my 93. If that HX-35 fits I would imagine there's others too. Good luck! Chuck
Old May 11, 2006 | 03:51 PM
apwatson50's Avatar
Any turbo up to at least 02 or whenever they stopped using the vp44 pump will work. However they will take some modification to work on a 1st gen. Because they have a wastegate in the exhaust housing it is about 1.5" longer. So the down pipe will have to be moved back the appropriate amount. Now if you have a non I/C model you will have to do some fab work for your fresh air crossover pipe.
Also the exhaust housings are interchangeable between all the holset turbos used on these engines.
89-91.5 baby h1c
91.5-93 h1c
94 Wh1c
95-02(manual trannies) hx35
99?-00?(auto's) hy35-nothing interchangeable with this turbo and the
h1c/wh1c/hx35
02+????
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Boomchadda
16
Feb 11, 2008 05:29 PM
Ada381
Feb 10, 2008 07:58 AM
Inline5.9
Aug 19, 2006 10:22 PM
Cummins Freak
Feb 16, 2006 06:59 AM
powerwagon440
Jan 20, 2003 08:50 PM
