need U joint help
need U joint help
hello its a little off topic but i need help i have a 86 dodge 1/2 ton 4x4 that keeps throwing a cap off the drivers side axel U joint if i put it in 4 wheel been doin this ever since the axle bearing was repleaced the little needle bearing the the end of the axle tube i cant figure it out makes the truck shake like Hell any help? Advice?
thanks dennis
thanks dennis
Are you using the right u joint? Only other thing I can think of is there isn't a tight enough fit between the cap and the "saddles", or there is a crack that isn't noticable and spreads out when under load.
All just thoughts
Justin
All just thoughts
Justin
thanks for the replies yes its the right Ujoint or what napa says is the right one the passanger side hasnt moved at all. Ill have to look for a crack i was thinking about maybe welding the cap on the Ujoint an see if that will hold it, what do you guys think?
I think NAPA is giving you the wrong U-joint, that U joint should have internal c clips on all 4 caps, if the c clips were installed there would be no way for the cap to come out.
If you weld it, the next time the U-joint goes bad you will have to buy a whole axle to repair it.
This is a Dana 60, but same concept, my knife point is on the position of the internal C-clip, you must have these installed or the cap will come out, like you are experiencing.
Have you installed these internal C-clips in your U-joint???
JD, if you weld the cap to the u-joint the cap will turn inside the yoke instead of pivoting on the needle bearings... won't take long till you'll need a new yoke.
If you haven't bent your drive shaft then the clips must not be holding the u-joint centered. Got any pictures? Lets us take a look maybe we can help.
When you go to Napa get in the old guys line. Usually there pretty smart at solving problem especially if you take the part with you. The young one are lost and to lazy to get the book out if the Napa computer doesn't have the answer.
