need some ideas on body work plz
i am currently working on replaceing all of my fenders,dors and the box...but i am not puting the trim back on so i am left with these holes on the lower corners that i dont know what to do with. i thought of welding them shut,grinding it down then mudin it, but i was wonderin if theres an easier way to do it thats gonna last another 17 years and look good too!!
thanks, ryan
thanks, ryan
Weld it, grind it and putty. that's the way we've always done ours. I did see where someone used a punch and punched out littel disc's. Then drilled the hole out to just a little bit smaller then the disc and used a bigger bit to radius the edges. Put the disc in and welded it up. Hope that makes since.
i would weld a piece of sheet metal ( a piece slightly bigger than the hole) on the inner side of the fender then mud over on the outside
remember you can fill a hole but you cant cover a mountain. when your doing body work
I'm currenty working on my truck getting it ready for paint. I took the the protective black side trim off and was left with 1/2 " holes in the cab and fenders. I think the best thing is having them welded. I didn't realize how expensive they are to replace w/ factory trim.
If you're wanting to save your paint, well I don't know
, but I would do tests some where inconspicuous, like under the dash or inside the wheel well.
If it were me I would put a piece of metal on the inside and then fill the hole with weld (carefully as to not get sheet metal to hot) then grind the weld down and bondo overtop.
I just welded the trim holes on mine shut and ground them down. On the bigger holes I cut a piece of sheet metal to fit then welded it in. Just don't get in a hurry, it doesn't take much to burn a hole. Mine turned out pretty good.
You might have the best luck with brazing the holes closed. I'd be worried about bondo popping out, it might not be possible to get a piece of sheet metal behind the holes, and filling in the hole with steel is kind of overkill.
Go to a Body Shop Supply and get yourself an Eraser Wheel, you chuck it in your power drill and it removes decals, pinstriping and foam tape from the paint without damaging the finish.
You will wonder how you ever got along without it.
http://cgi.ebay.com/ebaymotors/Snap-...motiveQ5fTools
http://cgi.ebay.com/ebaymotors/3M-St...motiveQ5fTools
You might have to buy the mandrel separately.
Jim
Jim
Jim
