Need some advice on mods
Old Oct 25, 2008 | 12:56 PM
d3504me's Avatar
ok here is the story i have a 1992 d350 dually 4x4 it runs strong everything is great it has everything stock on it i just got the truck last week i want power and lots of. i have been looking at a turbo from purecummins.com its called a High Tech Turbo PRO STREET 66 94-06 Dodge Cummins from High Tech Turbo
And maybe methonal injection im not really sure i tow with this truck and i want to be able to do some racing with it im fairly apt mechanicaly and i work on my tractors myself so i just basically need some info on what to get and like ideas i also want to put stacks on i was thinking like 7 or 8 inch slant cuts is there any disadvantage to like having an open top like should i cover it or something and should i use the same diameter tubing allthe way back from the turbo to the stack split im kinda cluless lol my massey fergusen tractor has a 5inch stack that comes staright out of the turbo im not sure what to do in regards to the truck so anyhelp yall could give me would be grerat im open to droppin big bucks on this trucks cause i just got a new job so tell me what to do yall thanks so much
Old Oct 25, 2008 | 01:08 PM
WEell before you get that giant turbo you'll need fuel. which means custom injectors and pump mods and a good fuel system. start out with the basics for now. pump tweaks. BHAF. exhuast. get used to everything
what tranny does it have? this will hold you back
Old Oct 25, 2008 | 01:34 PM
RuralCruiser007's Avatar
How about we start with the basic necessities: Gauges. You will need a boost gauge (60 psi), pyrometer, and fuel pressure gauge. With this you can then moniter what is going on.
From there your pocket book is the limiting factor.
Welcome aboard!
Old Oct 25, 2008 | 01:59 PM
d3504me's Avatar
Thanks
thanks so much im stoked i found this site it has a 5 speed tranny and i do have gauges i should have said that prolly i have a 100psi boost gauge a 100psi fuel pressure gauge and a 2000 degree pyrometer mounted on pods on the dash
Old Oct 25, 2008 | 02:13 PM
sweet. you should get a clutch before you add big power. Its just good to have because you never know about your future upgrades. Go with a southbend CON FE 13 inch. That will handle all your power needs...For right now look in the sticky article at the top of the forum for simple pump tweaks. Id start seriously thinking about injectors.
Custom EDM 6x16s seem to be what everyone likes. you could send your stockers out to scheid diesel and get them custom cut to 6x0.16.
do you already know about the VE pump itself? like the tweaks and stuff?
Old Oct 25, 2008 | 03:28 PM
d3504me's Avatar
pump tweaks
no i dont know much about pump tweaks i was reading on purecummins.com about something called a smokey power pin is that something i would want also they have alot of diffrent injectors on that site and i was wondering which are better and as a side note as of right now i have 4 inch staight pipe exhaust dumping out right behind the drivers door is that like ok im fairly handy with a welder and i did it myself one of my buddies has a mandrel bender and thats how i got the bends in it so there arent really any kinks either
Old Oct 26, 2008 | 01:26 AM
peobryant's Avatar
As far as fuel pins go, I would buy a DennyT stage II fuel pin. Everybody that runs one loves it, and I will be buying one shortly. He says you can expect around a 40hp gain from stock, and they are $100 to your door. If you are interested, you can PM him on here. But before we can help you with your mods, we need some pics of the truck
vwjunkie53
Oct 31, 2007 12:46 PM
bsj04
Sep 20, 2007 08:09 AM
Dusty Ratcliff
18
Mar 21, 2007 03:27 PM
ryan466
Aug 30, 2006 10:10 AM
ib516
Dec 30, 2005 11:05 AM
