Need to replace Getrag rear seal and spicer 70 pinion seal, HOW HARD????
I have a leak at the output of my getrag and since I'm running Royal Purple i dont want all that money dripping out on the road, so how difficult is it to swap seals?
My rear diff pinion seal is leaking too and I hate the way it slings oil everywhere. How difficult is it to change this seal?
Thanks for any help!!!!!
https://www.dieseltruckresource.com/...d.php?t=147766
A year after redoing my Dana, the pinion seal started leaking. It was a steady leak. I eventually discovered that the vent was plugged. I now check this whenever I service the truck. It is very important that the vent be clear as moisture accumulates in the gear oil and on the first long trip in the spring the vapour pressure will force gear oil out past all seals.
Maybe I should check the getrag vent line too, it could be blocked also causing it to leak.
ramruff
Wanted
Aug 25, 2015 09:58 PM
BC847
Jul 30, 2013 08:48 PM
