Need a power source
Old May 13, 2011 | 06:38 PM
foxtrot's Avatar
Need a power source
I'm finally getting to hook up my pre luber and need a power source under the hood, preferably on the driver side. It needs to be hot when the key is on run and start positions. Not a lot of juice is needed, its just for a signal.
Old May 13, 2011 | 06:39 PM
BC847's Avatar
1st Generation Admin
The blue wire going to the fuel shut-off solenoid ~ JUST for a power-up signal).
Old May 13, 2011 | 06:55 PM
foxtrot's Avatar
They all seem to be black to me. Is that the one down low on the IP
OK thats the KSB down low
Old May 13, 2011 | 09:18 PM
BC847's Avatar
How about any of the two wires going to the shut-off solenoid . . .. ?
Old May 13, 2011 | 11:05 PM
It's right where the injection lines going into the back of the injection pump.
Old May 14, 2011 | 06:27 AM
foxtrot's Avatar
Ya I know now. One of those gave me a lot of problems once. Truck kept diying couldnt figure out why.
The connector on one of those wires was worn and loose. Kept loosing contact with out falling off.
Old May 14, 2011 | 03:31 PM
foxtrot's Avatar
I found a better spot. The small wire feeding the forward heater relay. Just crimped an eye on my new wire. No need to mess with the factory wiring which is getting hard and brittle. Works like a charm.
Old May 15, 2011 | 08:40 AM
Douglas2's Avatar
hey-Hey!!!,
WHen I put on a 4601 electric lift pump I used the FSS power to trip a relay primary to power the fuel pump. The only additional load is the relay solenoid and it switches the higher current to run the pump. IIRS it was a 30A fog light relay. Also, if you're going to run extra stuff, the dual posted Optima Blue battery is quite useful. Regular posts for the OE stuff and a pair of 5/16" studs for the extras.
cheers,
Douglas
RamRat
Mar 24, 2006 07:24 PM
K2Cummins
Apr 29, 2004 10:38 PM
sc872
Oct 24, 2003 11:55 AM
Timinva
Jun 20, 2003 10:04 AM
