Need help good question about duallys
Old Oct 29, 2010 | 12:53 AM
dodge350c's Avatar
I have a buddy with a 2nd gen dually and i have a first gen dually and we were wondering if you could take the front hubs off of a first gen daully and put them on a second gen dually for the locking hubs instead of buying the kits. Thanks, Dominic
Old Oct 29, 2010 | 12:56 PM
MrExtreme's Avatar
I believe you would have to use the whole rotor, hub, knuckle assembly, but the 1st gen uses king pins while the 2nd gen used ball joints. The reason the kits are so spendy is that you can't just use readily available stock parts. AFAIK
I think the best way to do that would be to use a complete 1st gen axle, cut all the brackets off the 2nd gen axle and weld them to the 1st gen axle. It's a lot of work but it is doable, I did one for a friends pulling truck.
Old Oct 29, 2010 | 04:26 PM
dodgenstein's Avatar
The pinion is on the wrong side to swap 1st gen for 2nd gen housings and all.
Old Oct 29, 2010 | 05:04 PM
JustRamIt91's Avatar
Not many trucks use the passenger side drop xfer case other than the first gen dodge or some jeeps.
Old Oct 29, 2010 | 05:35 PM
All 73-85 GM fullsize were PS drop.
Old Oct 29, 2010 | 06:02 PM
MrExtreme's Avatar
I forgot to mention, we used a NP205 T-case, never been a fan of chain drive T-cases.
Old Oct 29, 2010 | 06:03 PM
MrExtreme's Avatar
I don't know of any GM 205s that had the circular bolt pattern to mount to a Rag or NV.
Old Oct 29, 2010 | 06:04 PM
Jer12377's Avatar
From: North Haven,CT "Living in occupied teritory" & Barton,VT
There is a right up on how to convert the 2ND gens to have locking hubs on another forum and I cant remember which one or find it in my saved sites. Is was a girl from New Hampshire that had a 2500 and used the assembly from a 90's Ford front end. If I can find it I will post it to this thread.
Old Oct 29, 2010 | 06:51 PM
KAyers's Avatar
From: Springtown Texas, the land of MILFs and Honeys
That write up is on the pirate 4x4 board. It uses cheap Ford parts to do away with those wretched cartridge sealed wheel bearings on the 2nd gen trucks.
Old Oct 30, 2010 | 01:35 PM
dodge350c's Avatar
ok thanks everyone
Old Oct 30, 2010 | 01:36 PM
dodge350c's Avatar
Where can i fint that wright up at
Old Oct 31, 2010 | 05:14 AM
KAyers's Avatar
http://www.pirate4x4.com/forum/showthread.php?t=874442
juicedbusa02
Nov 16, 2008 11:24 AM
Dogin
Mar 6, 2008 05:03 PM
Shaders 24v
Oct 16, 2003 05:51 AM
