Need help
Old Sep 20, 2009 | 04:25 PM
Wettstein's Avatar
Need help
Got a lot of play in the steering. Both tie rod ends are bad and the drag link ends are bad. Does anyone have the part#'s from napa for these parts.
Thanks for the help
Old Sep 20, 2009 | 04:47 PM
Napa has a website...http://www.napaautoparts.com/
Old Sep 20, 2009 | 04:57 PM
Wettstein's Avatar
thanks ive got that one all ready
Old Sep 20, 2009 | 05:09 PM
Wettstein's Avatar
I'm trying to find parts that peole have used and are happy with. My camber is way out, my tie rod end are all messed up and the ends on the drag link are nice and lose. I have allready replaced the bad steering shaft with th U-joint one and i still have a lot of slop
Thanks again for the help
Old Sep 20, 2009 | 05:55 PM
Wettstein's Avatar
One more ??. Will just replaceing the upper and lower ball joints fix my camber problem or is there somthing else taht has to be done
Old Sep 20, 2009 | 05:59 PM
TIMMY22's Avatar
Check the steering coupler on top of the steering box for wear.
Mine was all wore out and an $11 rebuild kit from the dealer solved the problem.
Old Sep 20, 2009 | 08:54 PM
Free89W350's Avatar
The ball joints will help and the camber adjustments on the upper control arms (at the pivot point) will do the fine tuning, as long as all the control arm bushings are in good shape. As far as part I go to either autozone or order them from RockAuto (they seem to be the cheapest I have found).
Old Sep 20, 2009 | 09:53 PM
Wettstein's Avatar
Are there barings in the pivot point that may be worn out also. Or are the ball joints all that are there at the pivot point?
Old Sep 20, 2009 | 10:23 PM
Wettstein's Avatar
What is the king bolt baring?
Old Sep 20, 2009 | 11:24 PM
93flatbed's Avatar
I think you're talking about the king pin bearing. One on top and one on bottom. And whats all of this talk about contol arms on your W350?
Old Sep 21, 2009 | 12:19 PM
Wettstein's Avatar
Ok thanks for the help. And i dont know what all the talk is about control arms on a W250. From the look of everything i am going to have to rebuild the outside of the axle . I hope it all goes fine. Is there anyone around the fort Reliy if i run in to a problem
thanks for all the help
Old Sep 21, 2009 | 06:01 PM
82F100SWB's Avatar
These trucks have kingpin front axles, the upper has a steel cone and plastic cup with a preload spring, the lower is on a tapered roller bearing. There are no balljoints to be found. It's really quite bulletproof and reliable, but, when things wear out, you can have camber issues without any play in things. I'm pretty sure my truck needs lower bearings at this point, I did the upper bushings when I got it, and the camber is better, but still not 100%.
http://extremeaxlesales.com/dana60ki...ebuildkit.aspx
That's the kit for one side, going rate online is around that same price, most local parts stores are considerably more expensive.
Here's a pretty good re-build article:
http://www.pirate4x4.com/tech/billav...pin/index.html
Old Sep 21, 2009 | 06:34 PM
Wettstein's Avatar
kingpin front axles
Thanks you, that is the first time i have heard that kind of info, Now one more ? are the axles the same on all the first gen years 89-93?
Old Sep 21, 2009 | 08:35 PM
82F100SWB's Avatar
The only difference is the wheel hub/locking hub style, as far as the axle itself is concerned, the steering and kingpins are the same on all the 89-93's, be it a 60 or 61.
Old Sep 21, 2009 | 08:40 PM
archer39's Avatar
here is another source for the king pin rebuild kits. you will need the 7/8 hex wrench that they offer if you do the rebuild.
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
