need a blue truck paint code
I did send the owner a PM but hes not on line much.So if anyone has the same paint colours
the paint code is on a sticker under the hood or the rad support
heres the truck needing some colour
I think you will find its a metal tag on the passengers side firewall. There are tons of codes on the tag. I had to call napa so they could tell me what code location they needed. On a 2 tone you ( obviously ) will have 2 codes. A primary and secondary paint code.
Thanks guys, richie if its the tag with 3 lines of numbers it should be the numbers on the second row , second and third set of numbers.
My parts truck has a sticker that was under the hood
Driver121 It looks like the same primary as my donor truck , said electric blue on the dealer window sicker .
For the two tone Blue Metallic paint. There are three different silvers listed in my 93 dealer build book.
All the pic's shown so far seem to be the darker silver code# PS7. This one is called Sabre Gray Metallic clear coat.
The second gray is called Light Sand Metallic clear coat code# PV4. It is a lighter color gray.
If you want an even brighter silver color. Look at Silver Star Metallic clear coat. code # PAC. This one has silver metal flake in it.
The Electric Blue is code PC3
cool thanks guys , i have ordered the primary colour so i can start the interior painting .
had to get some paint stripper today because all the factory paint on the roof is cracking , hopefully it will be eraser than sanding the whole thing.
http://www.tcpglobal.com/autocolorlibrary/
This seems to be the best link for finding your paint codes that I have found.
Good luck. I'm doing the same thing. And it's the same colors as you. Off the top of my head I think my codes are pc3 and pc4.
Hope that helps!
Hope that helps!
mullishacrew
Mar 19, 2012 09:05 PM
brophyn70
Dec 20, 2010 03:23 PM
st.rodder2
23
Dec 17, 2008 10:47 AM
RJOS
May 27, 2007 10:19 PM
Dodgezilla
Feb 18, 2004 07:53 PM
