nasty screach/wistle noise.... help!
Old Apr 17, 2006 | 11:02 PM
TurboShadow's Avatar
Hey guys, my truck decided to start making this nasty screaching/wistle noise the other day on the way to town. I stepped on the brakes and it went away. Didn’t do it for a few days. Now, it is doing it all the time, and it’s very loud and very annoying. But the weird thing is all I have to do is lightly press the brake pedal and it goes away. For some reason it wont do it when it is idling, in park or neutral. I also jacked up the back end and started it, and drove the truck and couldn’t get it to do it. But as soon as I took off down the road it started again.
Please help!
Dustin
Old Apr 17, 2006 | 11:08 PM
goodtyms's Avatar
Have you checked the U-joints? The driveshaft can confuse the issue by acting as a tuning fork, but I've had u-joints that did that, only under a load.
Old Apr 17, 2006 | 11:15 PM
flashgordon's Avatar
Sound like you might need brakes or something is stuck in there!
was it coming from the front brakes or the back?
Old Apr 17, 2006 | 11:20 PM
It really sounds like it is coming from the front. I also drove over a few bridges and it "echoed" off of them.
The front brake thing makes sence, but I would think that it wouldnt be so intermidant. I jacked it up and ran the back end... I doubt its a u-joint or anything like that, because it didnt make any noise.
Old Apr 17, 2006 | 11:28 PM
derek840378's Avatar
i would say a caliper may be stuck. u may try lubin' the caliper bolts
Old Apr 17, 2006 | 11:47 PM
with something like lithium grease?
Old Apr 18, 2006 | 09:11 AM
alborada's Avatar
You may just have a small rock stuck between the rotor and the dust cover or the caliper area somewhere, my fords used to get one all the time just have to take the wheels off and look around with a rubber mallet.
Old Apr 18, 2006 | 09:17 AM
remove the front calipers and if the brakes are still good, look for uneven ware between the iner and outer shoe....sorry BRAKE FRONT PADS!! (One pad is wore out and the eter look new) if thay are, make shore that the sliding pin of the caliper will move with you hand. If not i would replace the caliper/s but if you clean all the rust off of the pin and clean with brake cleaner,and grease(As was mention below you will be fine!
With that said i still vote for somthing geting wedged in there some ware!
Final note: if the bearings were bad in the front or back casuing the wheel two tip(allso just way loose bearings)could cause a noise also
Old Apr 18, 2006 | 09:22 AM
Thats funny, my wifes EX-SPLOODER PICK UP A ROCK EVERY TIME SHE TAKES IT OFF ROAD. some day i will get her out of that P.O.S
12valve@heart
Oct 12, 2007 02:03 AM
RelaxedCrewCab
30
May 26, 2007 11:50 PM
Common
May 25, 2007 02:37 AM
Hondasucks
Apr 30, 2005 02:06 AM
RonP
Oct 3, 2004 02:16 AM
