mystery clunk front end
Old Nov 6, 2010 | 10:52 PM
D-RAM's Avatar
Stock 91 w250 4x4, locking hubs. Its not the u joints or the front shaft but Im getting a clunking from the front with forward motion. it's really bad when I try to engage four wheel but also does it sporadically with the hubs free and in 2Hi range.I think the cold gear oil still turns the front diff enough to create the clunking, so I am thinking front diff. It's never been apart and its plowed enough snow to cover Mt. Everest!! Is there a particular part in the diff I should focus on? Or am I way off base here?
Old Nov 7, 2010 | 12:09 AM
ratherberacin's Avatar
i had a mystery clunk and it was worn/missing sway bar bushings.
Old Nov 7, 2010 | 12:26 AM
rebal's Avatar
look for cab mounts core support mounts u bolts worn sping bushings even a trans mount can transfer a clunk
Old Nov 7, 2010 | 01:02 AM
schamran's Avatar
Just a though, but on my truck, either the brake slides are worn on the front calipers, or the slides were worn on the knuckle. The brake calipers would move forward a little whenever I touched the brakes after using reverse or rolling backwards. Just a thought. To fix it I added material to the leaf spring-like object between the bottom slide and the caliper. Clunk gone. Crawl under there and make sure the calipers are tight in the slides.
Old Nov 7, 2010 | 07:41 AM
D-RAM's Avatar
Thanks for the ideas , I will look at them all.
D-Ram
leeboy
33
Feb 22, 2012 08:20 PM
Cummins610
17
May 29, 2010 12:50 AM
MasseyMan1089
May 23, 2007 07:56 PM
dpeder
Feb 21, 2006 11:34 AM
mrwaters
Nov 11, 2005 10:31 AM
