my feet are always cold!
Old Nov 15, 2010 | 12:53 PM
92smokin blacky's Avatar
Well now that the season is changing again and its getting colder, along with inside my cab. My truck gets hot when the truck warms up and will run ya out of the cab it gets so hot, but to get the most heat out of my truck I put it on Vent and turn it all the way up. It gets really hot and blows through the vents but thats how it makes the most heat, if I turn it to heat instead of vent it will put the heat to the floor but it seems like it barely comes out and doesn't get hot as fast. So I had an idea and was thinkin about cuttin a hole in one of my vents and running some 1" or 2" duct down and direct it to my feet because they are always cold when I'm driving but the rest of my body is warm from the vent. I wish you could put it on both vent and feet like the newer vehicles. Anyone done this or anything similar? I don't think it'd be too hard to do.
Old Nov 15, 2010 | 01:13 PM
BearKiller's Avatar
Have at it and post back with your results.
It is probably just a big dead rat or somesuch blocking the floor vent.
Old Nov 15, 2010 | 01:40 PM
jesussaves's Avatar
i would just clean the floor vent first to see if that helps
Old Nov 15, 2010 | 04:51 PM
IRoss's Avatar
Is the door closing all the way in the heater ducting? The vacuum hose that controls the floor heat is under the steering column to the right...put a gauge on it to see if you are pulling the same vacuum as the other (defrost and vent) hoses..could be a loose or cracked vacuum hose..could be the hvac unit in the dash...
Old Nov 15, 2010 | 05:06 PM
GIT-R-DONE's Avatar
I would actually pull out the controls behind the dash, as the plastic that the rods are connected to generally breakor split, making it so you wont move the rods the whole way, causing the door to not open up all the way. I have had that happen on 2 of my trucks
Old Nov 15, 2010 | 06:49 PM
I'll look into it, I haven't cleaned out my hvac yet, but was still debatin on whether i need to or not, but might as well. Theres still air comin out of the floor vents but it doesn't seem like that much, and the vents do seem small. My defrost and ac works pretty good.
Old Nov 15, 2010 | 08:32 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
man i'm right there with you! I've gone over my HVAC system a few times and cant get it flowing right. I cant get the floor OR windshield vents to work right!
what vac #'s should i have, i'm thinking of taking the whole HVAC control unit out and testing the main vac supply line from the firewall.
the other thing i cant get to move is the outside air?inside air gate on the passenger kick panel.
Old Nov 15, 2010 | 09:32 PM
lovin1stgens's Avatar
i wish my truck would run me out of the cab lol i put a new thermostat in last year cleaned out the heater core best i could and it didnt improve much. kinda a pain in my butt
Old Nov 16, 2010 | 06:14 AM
#2isgreen's Avatar
Any chance this this could be a symptom of a weak vac pump?
Old Nov 16, 2010 | 07:46 AM
Subliminal's Avatar
My truck will run you out of the cab too...about 15 minutes after you start it in the morning! Brrrrr
Old Nov 16, 2010 | 09:23 PM
how'd you get it that way subliminal and 92smokin blacky?
Old Nov 16, 2010 | 09:39 PM
Dlowkes7's Avatar
i plug my truck in at night and its hot within 5-10 minutes of driving. it helped to completely cover the weird hole in the drivers side under the side of the dash. now my feet are toasty..
Old Nov 16, 2010 | 10:13 PM
yeah after my truck warms up, and the vent is on high, then it'll heat the cab up pretty quick, but not my feet!
Old Nov 16, 2010 | 10:45 PM
Crazy Matt's Avatar
Try to wear some wool socks and take the potato outta the vents.
Old Nov 16, 2010 | 10:48 PM
Dlowkes7's Avatar
I have also thought of your idea to add a couple of "vents" to the system. I would cut into the large black box under the dash. except i havent figured out what to use as a duct. maybe some small (one inch) or so black tubing. althought wouldnt it always be on when the system was on?
micstep
Nov 17, 2005 10:17 AM
crossy
Jul 20, 2005 10:39 AM
twhite
Dec 18, 2004 10:01 AM
NJMurvin
21
Apr 12, 2004 10:58 AM
