To mill the head or not??!!
is it possible to ****** a known good cylinder head and have the machine work done on that one for you? i realize that it'll be a little more $$$, but you'll have all the parts on hand, and all you gotta do is ****** the head off, prep block, put head gasket on and new fresh cylinder head, and you're ready to rock and roll....
Well to give you some idea, I just had Cummins replace my gasket. The head checked well within spec the first time they replaced it. After the 1st replacement blew they had the head decked flat, and put it back together. Now, in just 1 day, the second replacement blew! Now I haven't found out why this one blew yet, but deck the head, its worth the security, and make sure you re-torque the head at least 3 times...I'm gonna do 5 at this point.
With a 1990, you probably still have the old style head gasket, which is good to about 250K and no more than ~30psi boost. Exceed either of those variables, and you are running on borrowed time, IMO.
The head on my 91 (nonIC) was within .002" of flat end to end. I cleaned it up and put it back on. Ran another 70K before selling it.
My 92 needed milling. They took off .008" and I put a .020 over gasket on. I read somewhere that you need a super smooth, almost polished surface on the head and block to maximize sealing. My head didnt get that, so I may get another head later on....
DP
DP
The thing I'm referring to with the valves is that apparently, when machining the head, the valves protrude just that much more into the combustion chamber (for what it is).
It's a Valve/Piston kissing thing.
One has to be kinda funny about grinding the valves as was said earlier, the integral/OEM valve seats are induction hardened. --> The valve seats and the head are one and the same metal. A high electric current is passed through the metal of the immediate valve seat area there by hardening it. But only so deep.
As such, the OEM valve seat can only be machined once. After that, they must be cut out and replaced with a service valve seat (a ring of new metal).
Further, with the nature of the relatively small combustion chamber, recessing the valve too much in the head will drop the overall compression ratio. The FSM makes it sound as though valve depth is critical.
Read it for yourself
Machining the head:
Valve Seats (General) Note the reference to machining the head:
Valve Seats (Integral):
Valve Seats (Service/Replacement):
Sorry about the big images, I just wanted folks to be able to read them.
Hope this helps.
~ Machining the head:
Hope this helps.
From experience, don't deck it unless you have money to burn, and time to spare. Reseting the vales with be fun enough with out that. have it checked, clean it, get a good gasket, slap her together.
^^ Quite possibly the worst advice I've ever heard.
Do you want the job done...for now (could be a week, could be a year)?
or,
Do you want the job done...PERIOD?
Deck the head, then you'll only have to buy one new gasket!
or,
I know of many successful "just swap the gasket" head gasket changes on our engines. On a high mileage engine, head gasket failure is usually nothing more than a tired head gasket. As long as the head and block are straight and smooth things will be fine for another 300k. But it is risky to just throw a gasket in there without checking things over thoroughly, so you need make sure the head and block deck are in spec.
SKATERHAULER
Sep 2, 2011 03:46 PM
mulisha
33
Mar 10, 2009 07:51 PM
Dufrain
Jan 6, 2005 12:03 AM
