Massive Loss of Power - And where to go for service?
Old Sep 2, 2005 | 04:37 PM
Originally Posted by ruquik
I am having the same problems, after calling 4 different diesel shop from coast to coast you guys have said everything they told me. Ya'll rock. I mpg is down to like 14.5 and last tank it was 19.5, Can the filter cause that kind of problem? By the way what do you think of this idea. On the banjo fitting going from filter to IP there is a air bleed screw. The line going from the lift pump to the filter doesn't have an air bleed. Is it possible or even logical to go to cumming and get the one with the air bleed and replace the one the doen't have it. Then I want to replace both bleed screws with fuel pressure gauges for pre and post filter, this would help to determine whether the filter is the cause.
Yeah, it can cause bad fuel mileage.
If you want to add pressure gauges, the easiest thing to do is get a couple tapped high flow banjos from Geno's Garage.
http://www.genosgarage.com/CoastalDa...ID=593&CATID=1
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
BEHRMAN
26
Feb 8, 2004 11:49 AM
timdewaltman
May 26, 2003 11:22 PM
