Macpherson Coil Spring Tool
Old Nov 4, 2008 | 02:09 PM
XCLR8N's Avatar
Question Macpherson Coil Spring Tool
HAs anybody used this tool? How well does this work? I am thinking about getting one in order to make the coil spring change out easier and wanted to know if anybody has any info on it?
This is the info I got off the internet.
STRUT SPRING COMPRESSOR
Repair Macpherson struts on or off the vehicle
Works on struts with springs up to 7" diameter
Perfect for body shops, specialty shops, tire shops, dealerships, independent garages and service stations
Max opening: 8"
Lead screw torque: 15 Ft. lbs.
Old Nov 4, 2008 | 03:28 PM
TJE's Avatar
TJE
No I haven't used one of them. I would NOT use one on these trucks unless it is rated for these springs. I changed mine using the info I found in the sticky detailing how to change the springs.....if the info is not in the sticky it is somewhere on DTR.
Good luck
Old Nov 4, 2008 | 05:38 PM
PapeCAT's Avatar
That would be an unneeded tool. You'll find that there isn't much load still on the spring when the suspension is fully extended. You raise the front end, take the rotor off, stick a floor jack or similar preloading the lower control arm a slight bit, then pop the lower BJ off, and slowly lower the LCA with the floor jack. The spring falls right out. The installation is the reverse of removal. I've done both sides on my d250 2 times, once to install the MOOG 7226S, then the 2nd time to install the DAYSTAR Coil Spring spacers...
Old Nov 4, 2008 | 07:15 PM
XCLR8N's Avatar
Are you running the 7226S and Daystars at the same time? You got any pics I was thinking of doing the same thing if that is the case.
Old Nov 4, 2008 | 09:31 PM
PapeCAT's Avatar
yes both daystars and 7226S, but I wore the 7226S in for a couple years and 40,000 miles before putting in the daystars... I have some pics, but I have since taken the ricksons off and put stock tires on so overall the wheel is 2" shorter now, which is more of a gap. Take note of where the centerline of the front wheel is in the wheelwell...
Actually nevermind I have a pic of the stock wheels with this set up as well...
And make sure you get a big beefy pickle fork. I used the fattest one I could find, as the standard one they sell at Harbour frieght and Autozone is too small. The "pitman arm" remover worked perfectly... Oh, and get a big mini/hand sledge to pop it off.
Old Nov 5, 2008 | 06:34 PM
XCLR8N's Avatar
Well this will definitly be happening in the near future as I have front end sag.
Old Feb 23, 2009 | 09:20 AM
PapeCAT's Avatar
Sounds great, post up some pics when you get the front end done.
Old Feb 23, 2009 | 02:04 PM
XCLR8N's Avatar
I will try and take some picture of the new stance, now that I got the new springs and shocks in the truck.
Old Feb 23, 2009 | 07:24 PM
911stgen's Avatar
where do i get those springs at ?
Old Feb 23, 2009 | 09:04 PM
PapeCAT's Avatar
You can order them from napa, carquest advance auto parts etc... MOOG 7226S
Old Feb 24, 2009 | 08:14 PM
XCLR8N's Avatar
Here are some pics of the new stance.
Attached Thumbnails Macpherson Coil Spring Tool-dsc02705.jpg   Macpherson Coil Spring Tool-dsc02706.jpg   Macpherson Coil Spring Tool-dsc02707.jpg
Old Feb 24, 2009 | 11:46 PM
Firstgenfanatic's Avatar
Wow! Nice work Matt! pickup stance looks good.
Mkinner
Sep 21, 2010 07:57 PM
flynhigh205
Feb 26, 2008 10:33 AM
SBishop
Feb 14, 2004 05:21 PM
ouchman
May 16, 2003 11:59 AM
ouchman
Apr 19, 2003 01:59 PM
