low idle when cold
Old Jul 14, 2008 | 08:06 AM
taterfarm's Avatar
low idle when cold
a few weeks ago my truck started to idle real low when it was cold, about 500 rpm, then it would be normal after a short ride. now its getting worse, it takes quite a while for it to go back to normal idling.
I run biodiesel and had a tankfull of not so great stuff so maybe that it to blame, but the truck is real smooth, even when idleing at 500rpm, it doesnt shake much. when I step down it responds fine and takes off with no problems. There is no definate miss like a bad injector either, unless they are all tired out which is a possability.
I am not sure what to think, just looking for some input. I am going to get a fuel filter after work today and see what that does. let me know if you have any comments.
Thanks
Old Jul 14, 2008 | 11:19 AM
Power Ram 250 C's Avatar
My truck will do the same thing when it is cold out on a start. Once it is warmed up it will come back up to about 750 rpm.
Old Jul 14, 2008 | 04:16 PM
921stgen's Avatar
When I put 12 gallons of straight soy oil in the truck in my sig to top it off mine did the same thing bcause I didn't really drive it much because for four months of being off work it got really cold.
Old Jul 15, 2008 | 07:05 AM
taterfarm's Avatar
I drive the truck every day, and it is in the 70's to 80's most days.
Old Jul 15, 2008 | 10:07 AM
roxxx's Avatar
There are high idle throttle screw control that you can use or as in my Brother in laws case he used a solenoid and switch, flick the switch and you have preset high idle . the old school one is used in a lot of the older big rig trucks and farm trucks may want to try princess auto or some Ag place
APD
Jan 31, 2023 08:03 PM
slickr1
Jan 26, 2012 01:16 PM
Ram1999
Feb 11, 2007 10:49 AM
JonR
Dec 11, 2006 09:04 AM
busted
Feb 16, 2006 08:49 PM
