lope or fuel knock? I'm not sure
Old Jan 23, 2013 | 06:54 AM
93-12Smoke's Avatar
I just installed my new IP and 5x.014 injectors and after cranking the truck it definitely has a new sound at idle. To me it sounds like a lope but my friend thinks its a fuel knock. The sound goes away as soon as you bring it up from idle. The pump is basically stock with a 3200 spring and fuel pin. II built the pump and i did not change anything yet. I set it with a hair of timing advance, just barely over the line from the factory pump. I just installed it where my afc boost tube was already bent to from the previous pumps timing advance. The pop pressure on the injectors were set at 255 bar.
I am running the same set up on my 4bt but didn't notice this same sound on it. Of course that motor has no harmonic balancer and rattles like crazy anyways.
I figure i can adjust it out with timing but am curious if that kills the benefit of the increased pop pressure.
Old Jan 23, 2013 | 08:20 AM
dB Zac's Avatar
A diesel shouldn't lope. What's your idle RPM
Old Jan 23, 2013 | 09:13 AM
93-12Smoke's Avatar
No tach so I'm not sure on idle rpm. It's definitely lower than my old pump was but i had it idled up a little bit.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
John Rodriguez
Sep 28, 2005 11:46 AM
