line locks and RWAL
line locks and RWAL and rear disks
today I was puting in my borgston steering shaft. SO here I am removing the rag joint and I see my firewall is cracked at the E brake bolts.
Their right under the main wiring harness going into the cab.
So i check for the dreded cowl cracks. None thank god. I can fix the crack easy weld.
Now for the ? will RWAL work with line locks? Also later on in time I'll be putin disks on the rear will the RWAL work with disks
Their right under the main wiring harness going into the cab.So i check for the dreded cowl cracks. None thank god. I can fix the crack easy weld.
The line lock won't affect the ABS.
The the RWAL won't work with discs, the reservoir in the dump valve is sized for wheel cylinders. The larger volume of calipers will mean it will only be able to dump the pressure a couple times instead of 20.
thanks Dave
Ok the dump valve is too small. How about a bigger valve off a different truck ? the 03 and up dodges have rear disks. Or its that a adifferent system ?
339K&Counting
Dec 4, 2013 10:36 PM
justagoodolboy
Jan 3, 2008 03:06 PM
