left me stranded! Need Help Fast!
Old Feb 15, 2010 | 10:29 AM
marcus marshall's Avatar
Angry left me stranded! Need Help Fast!
i was driving home from work listening to the radio and then the radio died and the engine stut off. i coasted to the side but it would not even turn over like the starter wasnt even there all other electronics worked and my battery read 12.7v so that was good.i checked the all the fuses i think and they all seemed good. there was no smoke coming from anywhere but there was a slight oder of something burnt near the battery. could i have a short somewhere? i already pulled the dash apart and looked for fried stuff but no luck. any advise would be appreciated. thanks for reading guys
Old Feb 15, 2010 | 10:32 AM
Crazy Matt's Avatar
Id check to see if one of the power wires came off the pump
might just try putting power to the pump- if that dont work
Old Feb 15, 2010 | 10:35 AM
i dont know. it shut off quick along with the radio. and theres no response if i turn the key
Old Feb 15, 2010 | 10:37 AM
PapeCAT's Avatar
In a pinch you can hotwire the pump / fuel shutoff solenoid + turn it over by shorting the solenoid (make a jumper for the Two wire oval connector that comes up from the starter) and see if it starts. If so, you may have fried something like a fusible link but you probably don't have a continuing short because something would be baking under the dash or hood.
Old Feb 15, 2010 | 10:43 AM
jogl's Avatar
X2 fusible link.
JP.
Old Feb 15, 2010 | 12:57 PM
dillenger1's Avatar
ignition fuse link is probably blown.Go get an in line fuse at the parts store and use that instead
Old Feb 15, 2010 | 03:09 PM
Could also be the ignition switch, in the column.
Old Feb 15, 2010 | 09:08 PM
JustRamIt91's Avatar
interested, subscribed.
Old Feb 15, 2010 | 09:42 PM
whosdunit's Avatar
Dodge uses in line wireing, and mostly their wireing is to light for the loads,I have noticed when wireing in a radio with out proper plugs,folks tend to wire to any wire that is hot!,Check that radio wiring--can't hurt. whosdunit
Old Feb 15, 2010 | 10:20 PM
torquefan's Avatar
Find the fusible links, and give each one a little tug to see if the conductor is melted through, inside the insulation. Have seen several times, a short will develop in the power wire for the fuel shutdown solenoid, behind the throttle plate bolted to the injection pump.
Old Feb 16, 2010 | 04:40 AM
i think ive found it. ive done some reasearch and im about 90% sure its a faulty ignition switch. i guess i need a new one
Old Feb 16, 2010 | 09:45 AM
93 12v's Avatar
Make sure your getting power to it before condemning the switch....
Old Feb 16, 2010 | 03:30 PM
93-12Smoke's Avatar
Well it not just going to be the fuel shut off if it wont spin the starter too!
Old Feb 16, 2010 | 05:00 PM
apwatson50's Avatar
If you smelled something burnt next to the battery, I would look closely at the fusible links in the harness next to the hood hing. I would say the chances are better being a link then the switch. As mentioned check to make sure there is power to the switch before replacing it!
Old Feb 17, 2010 | 08:00 AM
KRB's Avatar
KRB
My dad's '93 did the exact same thing. Ignition switch went bad and fried the fusable link for the orange wire.
