leavling kit d350
Old Jan 14, 2010 | 06:00 PM
adam greene's Avatar
leavling kit d350
why dont some one start making these, anyways on the other tread is says using a custom cut spacers anyone know how it is cut? anyone ever lifted there 2wd with spacers
Old Jan 14, 2010 | 07:33 PM
why not the spacers its in the sticky, whats wrong with using them
Old Jan 15, 2010 | 04:11 PM
need some help guys i know someone has done this
Old Jan 15, 2010 | 04:57 PM
jimbo486's Avatar
nothing wrong with those. all they really are is a 2" or 3" tall spring insulator. i bet no one's making a kit because it's cheaper just to buy the pair of spacers yourself and install them yourself. if someone bought them and sold them as a kit, they'd just become a middle man for you by ordering the spacers, you paying that person and that person then having to ship them to you. it'd probably cost you more than it's worth for that person's "services". and by cutting, i believe they mean cutting the 3 studs that are on top of the spacer? the daystar spacers are the ones from '94 and up 2nd gens. not sure if they differ much between 4wd and 2wd trucks, but my guess is the studs are on the 4wd trucks having the shock tower mounted above the spring pocket on the frame.
Old Jan 16, 2010 | 02:17 PM
1st gen wontabe's Avatar
http://cgi.ebay.com/ebaymotors/1971-...fAccessories(I used the part#1905 .It states that it will lift from 1 7/8 "to 2 1/4" they lifted my truck 2".I did this rather than buying new springs because I figured the new springs would settle just like the originals did.I don't think my old ones will settle any more .the applacation chart does say they are for 1/2,3/4,and 1 ton 2wd.I am happy with the way I looks and rides
Old Jan 16, 2010 | 05:09 PM
thanks alot were they hard to install? do they go on top or bottom?
Old Jan 16, 2010 | 05:42 PM
jimbo486's Avatar
the ad says they are to be installed on the bottom of the spring. they rest down in the taper of the lower control arm where the spring would normally rest. if you look at the picture closely, you can see that the spacers even a taper to them just like the bottom of the spring.
Old Jan 16, 2010 | 07:53 PM
I installed then when I was rebuilding the front end.I mean everything.4 ball joints,upper & lower control arm bushings.I had the control arms off to replace the bushings anyway so it was a good time to add them.I had a friend with a lift,four of us tag teamed it.jimbo is right
bulltamer
Dec 6, 2010 06:14 PM
banzaitoyota
Sep 29, 2003 02:34 PM
BmrHalr
Jan 6, 2003 01:31 PM
Rammer64
Dec 11, 2002 10:47 PM
chdiesel
Nov 3, 2002 04:39 PM
