Leaf spring question
My 92 W-350 has a GM 14 bolt which is offset to the rear (not centered in the fenderwell with bed on) does anybody have the dimensions of the overall length and each end to center unsprung cause they are off the truck. Would like to correct this problem if I can find exactly what the problem is. Also how many leafs do these trucks run mine has like 11 or 12 don't think this is right either. Any info would be great.
You owe me a beer....
Those are for the front. You can now find your rears in the same locations.
http://www.sdtrucksprings.com/index....0c5c29caa6c001
Gladly thats a small price price to pay for good info. Thanks a bunch. Still trying to figure out just exactly what has been done. Looked at the Chevy leaf packs on there and even they dont have as many leafs as mine has. I'll check the dimensions this evening.
Ok next question. Talked to SDspring in the above post my spring pack had correct numbers indicating a 10 leaf pack 24x28x52 overall length. According to them this was a heavy duty option. The question is why does the axle not set centered in the fenderwell? Could it be the shackles? Does anyone know what the dimensions of stock shackles are? Any other suggestions why the axle would be offcentered?
I am guessing the leafs are from a chev (came with the 14b rear), 56'' chev springs where offset and may be different than a dodge offset.
What did your rear shackle angle look like?
The leafs are dodge checked the numbers to be sure that's what I was hoping for it would have been an easier fix. The shackles were about 30 to 40 degrees off set to the rear. Thinking the shackles may be what's wrong. They are 6 inches overall and 4 inches hole to hole. Thought since these 10 leafs were an option the truck might have gotten the wrong shackles from the factory guessing.
Biltit
That's what mine look like only I don't have the helper springs on top. Looks like yours are 10 leaf as well. Pics wont load from my phone or I would be glad to. I'll put them on tomorrow.
Those are from a 1 ton chevy i used to have.
You can compare:
http://www.sdtrucksprings.com/index....oducts_id=7359
You can compare:
Here are a couple pics of the leaf pack and shackle. Sorry dont have one of it put together with a side shot to actually show you what i see. Still kinda leaning toward the shackle being wrong but i dont know.
