KSB leak
Old Jul 23, 2004 | 08:31 PM
Craig93's Avatar
KSB leak
Lost a screw holding my KSB to the pump and am losing a bit of fuel, anyone know the size of the screw, or what I will lose other than fuel if I pull the other screw out to match it up?
Thanks,
Craig
Old Jul 24, 2004 | 09:17 AM
Monty's Avatar
Not sure on what size of bolt you will need. However, most pumps will have a shim between the KSB and the timing piston. Make sure you dont lose it when you take it out.
Old Jul 25, 2004 | 11:55 AM
Craig93's Avatar
Got it done, thanx Monty. That sure is a stiff spring in there! Glad to be injecting my diesel instead of leaking it!
92smokin blacky
Jul 17, 2012 01:33 AM
CRToney
Jul 29, 2009 05:42 PM
Kas93
Oct 28, 2008 04:27 PM
59FORD
Feb 26, 2007 06:44 AM
JDOGEFOX
Feb 23, 2007 06:42 PM
