Key wont work in door locks...
Old Jul 23, 2004 | 11:05 AM
Chrisreyn's Avatar
"When you use the key it is a mechanical linkage. My power locks work fine but for some reason doesn't pop the **** up all the way. Seems to hang on something."
I had this problem with my 84 D350 gasser. The issue wasnt in the door at all, it was the latch post on the door pillar being out of alignment with the latch. I moved it slightly and the problem cleared right up....
Old Jul 26, 2004 | 01:31 PM
spunbearing's Avatar
Good luck... seems to be a common problem and I haven't found the solution yet. If you figure it out let me know!
Old Jul 26, 2004 | 09:30 PM
spitzair's Avatar
I had a similar problem not too long ago, turned out that it was the actual opener button mechanism for opening the door from the outsided that was the problem, the thing was seized up and wouldn't return all the way up thereby effectively jamming the key/unlock ****... Cleaned all the corrosion off and it was good as new. Hope this helps.
Old Jul 26, 2004 | 09:59 PM
Rammer64's Avatar
I have the same problem on my passenger door control. If I use the power locks from the passenger side, I have to push up several times to unlock the drivers door, but the drivers door works fine if I use the drivers side power lock.
Old Jul 28, 2004 | 03:29 PM
uncleroty's Avatar
I've had the problem to. A little graphite spray freed it up (shot into keyhole and in and around the latch). Just give a little shot twice a year to keep the problem at bay.
Old Jul 30, 2004 | 11:44 AM
fishermansteve's Avatar
I have the same problem on the drivers side door. Also, I can only lock the door before I shut it or I can't push down the button. Seems the jarring of shutting it causing a problem.
Old Aug 28, 2004 | 10:23 PM
hippie's Avatar
Hummm, That's the same problem I have with mine. Suer wish I could get it fixed. I would hate to break a key off in the lock..
Apocalypse
Jul 1, 2008 12:09 PM
nomad65
Aug 20, 2007 06:01 PM
Satan's Chariot
Apr 18, 2007 03:31 PM
PK
16
Dec 18, 2003 03:06 PM
