Key on power after external voltage regulator
Old May 25, 2026 | 10:13 AM
Rug_Trucker's Avatar
5 Year Member
Originally Posted by nonrev
Rug_Trucke, if IIRC you also disconnect the voltage reg when you do that
The regulator is in the ECM on a 91.5-93. So the computer is removed from the equation. I disabled one contact with the install. Truck isn't home or I would take a pic. It may not be the same for the external 91 back trucks. So far it is doing good. Eventually I am going to go with a PA or similar 1 wire with the 200amp out put. Might be in need of more juice with the future plans which will not be mentioned at this time.
918dodge
25
Feb 6, 2016 09:43 AM
cliffhanger1227
Nov 5, 2010 10:26 PM
brian diesel
Mar 2, 2010 09:51 PM
Jose Simpson89
Apr 24, 2008 12:22 PM
1340
Jan 15, 2005 07:53 PM
