Kerosene
Old Oct 7, 2004 | 07:19 PM
racermatt2606's Avatar
Kerosene
Can i put a couple of gallons of kerosene in my tank to clean out the motor. or does kerosene mess it up.
Old Oct 7, 2004 | 07:30 PM
darkvader's Avatar
LOW LUBRICITY OF KERO CAN BE A PROBLEM, A LITTLE IN WINTER TO REDUCE GELING(VERY LITTLE). WHAT ARE YOU TRYING TO CLEAN UP. WE USED TO RUN A LITTLE ATF IN BIG TRUCKS (1 QT. PER 100 GALS) BUT THERE ARE BETTER ADDITIVES OUT NOW.
CLARK
Sorry about caps
Old Oct 7, 2004 | 07:40 PM
ares's Avatar
you can run kerosene just add 5% oil because it wont lube the pump alone.
theres alot of good additives out there such as stanadyne.
atf would probably be a bad idea considering it has friction modifiers for the clutches in a tranny.
Old Oct 7, 2004 | 08:01 PM
dieselminded's Avatar
PM--------------Lightman ....................... about stanadyne
he'll learn you about aditives
Old Oct 7, 2004 | 09:41 PM
Forrest Nearing's Avatar
Kerosene isn't gonna clean out the motor...
Forrest
Old Oct 7, 2004 | 10:18 PM
Dieseldude4x4's Avatar
When it gets into the 20's around here, I use to add about two gallons per full tank but that was just to fight jelling. I use PS now.
Old Oct 8, 2004 | 08:07 AM
Redleg's Avatar
Kerosene won't hurt the engine, but I've seen it mentione a few times that it's not good for the pump. Not just lack of lubricity for the pump, but sulfer causes the seals to swell. No problem when you stick with Kerosene, but switching back and forth, the seals will try to return to their normal size and swell up again. I'm sorry i don't have the source, but I don't see a reason to doubt this and would not risk it.
dieselminded
Feb 25, 2026 06:16 AM
kingofdodge7131
Nov 1, 2004 09:39 PM
EdsGarage
Dec 13, 2003 06:12 PM
fanofthewolf
Aug 25, 2003 11:05 AM
Shepherd57
Oct 15, 2002 04:10 PM
