Just installed the BHAF
Just got the bhaf istalled and all I can say is holy moly. Seems to run cooler over the KN filter more turbo noise seems to spool up quicker and
. I should have done it long ago.
Originally Posted by sho_shane
what is the item# at orlley auto parts or autozone?
Part Number: 42790
UPC Number: 765809427907
Principal Application: Donaldson Disposable Housing
All Applications
Style: Air Filter
Service: Air
Height: 11.880
Outer Diameter: 10.500
Inner Diameter Top: Closed
Inner Diameter Bottom: 4.000
Ends: Plastic
Fleetguard part information for AH19037 is listed below.
Part: AH19037
Manufacturer: FLEETGUARD
Part Type: Air Housing, Disposable
End Connection ID: 101.6 mm (4 in)
End Connection Height: 35.052 mm (1.38 in)
Largest Housing OD: 266.7 mm (10.5 in)
Overall Height: 301.75 mm (11.88 in)
I just picked the Wix up at Napa. It was arouned $50.00 if I remember right. Jethrro
I just installed my BHAF and prefilter Friday, and I agree it is definitly something I should have done as soon as I got the truck, I had a new stock filter on it (about two weeks old) and after installing the BHAF it dropped my EGT's about 100* and I gained 2 psi of boost and the turbo does seem to spool faster!
Chris
Chris
VikingDiesel
Aug 12, 2006 08:02 PM
