jackleg!
Old Apr 17, 2011 | 08:06 PM
lovemysan's Avatar
jackleg!
I've had this truck for a month. The parking brake wasn't working and I have a spongy brake pedal also was leaking a gear oil out of the passenger rear wheel. I tore it down this afternoon to get it fixed. The previous owner had a shop/mechanic install "new brakes" and some other misc items. Obviously this mechanic had never been into a 3/4-1 ton axle. The axle nuts were both beaten off with a screwdriver. The passenger side had a screw instead of a locking pin. Ooh la la someone saved a $1.49 there. Neither park brake cables were attached...to anything. I'm not a mechanic but at least things work when I get done. Clearly the mechanic who received $75 an hour to complete this work was grossly negligent. This is the second first gen I've had to rework the rear brakes on. The other the PO claimed the rear axle had recently been "rebuilt". The one I test drove before that the owner claimed that the brakes "needed to be bled". I'm starting to understand the language.
Old Apr 17, 2011 | 08:15 PM
Boatnik's Avatar
Boy that looks familiar. When I pulled mine down the first time I found a nail instead of the screw in the passenger side but at least the parking brake was hooked up.
I now use(except in a roadside emergency) new nyloc nuts, new tab lock washers and blue lock tight.
I have even tried drilling and tapping the nut for set screws and that didn't work. It caused the nut to crack.
Old Apr 17, 2011 | 08:38 PM
whosdunit's Avatar
That nut is on the passangers side, does it turn to the left or to right to come off???
Old Apr 17, 2011 | 08:58 PM
cougar's Avatar
Some peoples heads should be used for golf tees.
Old Apr 17, 2011 | 09:01 PM
maybe368's Avatar
They are both right handed threads...Mark
Old Apr 17, 2011 | 09:09 PM
Totallyrad's Avatar
Wow!!!
Old Apr 17, 2011 | 09:11 PM
BC847's Avatar
1st Generation Admin
Wow!
Just Wow!
Old Apr 17, 2011 | 09:46 PM
THEBIGBULLY's Avatar
WHOOOOOOOOOOO, would I be pumped!!!!!!!!!!!!
That screw would end up someplace other than my hand!!
Old Apr 17, 2011 | 09:49 PM
BC847's Avatar
I wonder if the words "Hey beau! Gimme a beer!" were used in the making of this mess?
Old Apr 17, 2011 | 10:16 PM
whosdunit's Avatar
those screws ,,,,they don't come in chocolate flavor ,,,,do they????
Old Apr 17, 2011 | 11:19 PM
Brian.B's Avatar
it looks like they work like me,,,stand there scratching my head then throw all the new parts at it and hope they land in the right place,,
Old Apr 18, 2011 | 06:52 AM
ChrisLib's Avatar
what?...looks fine to me
*ducks*
