IRP 06 443hp dyno VIDEO
Old Sep 15, 2006 | 07:40 AM
bgilbert's Avatar
http://video.competitiondiesel.com/v...3d008cbbce.htm
Recorded off the TV from a DVD of the IRP 06 event.
Click here to see Video
Old Sep 15, 2006 | 08:12 AM
CTD NUT's Avatar
Cool! What bombs have been done to get 443 hp with the VE? What charger?
Old Sep 15, 2006 | 08:38 AM
bgilbert's Avatar
All stock. My old sig was something like this:
89 W250 93 Intercooler HTT SP66-14 Fire-Ringed Block 12mm studs KTA Special 14mm VE Scheid EDM's Piston Lift Pump ATS Manifold 6 gauges 60# valve springs SBC FE 4" exhaust
That be a SledPuller 66-14. Now I should say it has a 3200rpm spring instead of a 'custom' 3800rpm spring, Aeromotive A1000 electric lift pump, boost reference bypass regulator - set to 13psi base fuel pressure, max 30psi at 50psi of boost, 5/8" ID fuel pickup and supply line. Twins are next if I want to keep chasing HP. No giggle gas for me. Oh and I think it's got more rust. BTW, this is my good side.
Talk about truck ****. It's great no matter how many times I watch it.
Old Sep 15, 2006 | 08:49 AM
haloman's Avatar
How about the video from the diesel extravaganza?
Old Sep 15, 2006 | 08:51 AM
JD730's Avatar
Nice stuff Bill, its good to see 1st gens out there running good still.
bgilbert's Avatar
I don't know if anyone got it on video. I forgot my camera too.
Old Sep 15, 2006 | 08:52 AM
Begle1's Avatar
5/8's line?
I just ran 1/2 inch lines thinking that would be enough, dammit!
Old Sep 15, 2006 | 09:05 AM
bgilbert's Avatar
Originally Posted by Begle1
5/8's line?
1/2" is fine. Overkill I know. I actually have a 3/4" ID pickup tube and in tank filter . Then 5/8" from tank to regulator behind the battery on fenderwell. Short piece ~10" of 3/8" ID from regulator to inlet of the injection pump. My next project, the crew cab, I will only use 1/2" ID hose for supply. Probly use stock size return line though. I still have the stock return line in place on the 89 btw.
Old Sep 15, 2006 | 07:42 PM
Very nice! The truck looks fine once the smoke starts.
bgilbert
Jun 5, 2007 01:04 PM
DavidTD
Competition / Pulls / OffRoad
Jun 30, 2005 08:08 PM
Meatball
Feb 8, 2005 02:45 PM
