Intermetant Check Engine Light
Hey all,
Twice in the last two years I have gotten the check engine light along with low voltage and the #47 (I think) code indicating voltage expected low. Both times I was able to tap the alternator and the symptoms disappeared for the better part of a year. Obviously, I seem to be experiencing a failing alternator, but could it be anything else: loose diode, other, etc? I've never had a failing alternator be fixed with a slight tap and have it work fine for such an extended period. Thanks in advance!
D
D
Check the field connections real close. I've seen wired things like this caused by a very slightly loose crimp, or an oxidized connector.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
