Injectors, injectors, injectors
Old May 13, 2007 | 07:11 AM
KRB's Avatar
KRB
Angry
Alright, my "bad" injector reads: "937" inside an oval border. Up top is has "8965". Also says "KDAL 59 P 9 171 245 bar"
I pulled an injector from my brother's donor and its the same except instead of "171" it has a "266" and the copper washer is thinner. I was going to use this until I got new 190s but since its not identical I don't know if its the same and what effect that will have with the five "171"s?
Anybody know what these numbers mean? Can I still use it with the others?
Old May 13, 2007 | 07:17 AM
Ace's Avatar
Ace
I doubt it could hurt anything, 'specially if you're only running it for a short while waiting for new replacements. Heckuva lot better than running it with a bad injector, if you absolutely must drive the truck while waiting.
Old May 13, 2007 | 09:55 AM
Rampage1967's Avatar
Why not just use the full set???
Old May 13, 2007 | 10:13 AM
XLR8R's Avatar
Dave has the same torque wrench I do!
Old May 13, 2007 | 11:38 AM
KRB's Avatar
KRB
Thats an option but I was trying to take the quick, easy way out.
Old May 14, 2007 | 04:25 AM
KRB's Avatar
KRB
OK here's another ebay set:
http://cgi.ebay.com/ebaymotors/ws/eB...m=250114873911
Claims "50-70 HP...2 TO 3 MPG BETTER... IMPROVE THE THROTTLE RESPONSE, WILL NOT CREATE BLACK EXHAUST SMOKE, BUT RATHER WILL CLEAN UP ANY EXISTING BLACK EXHAUST SMOKE YOU HAVE NOW. THESE INJECTORS WILL ALSO NOT CAUSE A RISE IN EXHAUST TEMPERATURE OF MORE THAN 100 F, AND WILL DECREASE YOUR EXHAUST TEMPERATURE IF YOU ARE EXPERIENCING A LOT OF BLACK EXHAUST SMOKE NOW. I ALSO GUARANTEE THAT THESE INJECTORS WILL OUTPERFORM AND GET BETTER FUEL ECONOMY THAN ANY NEW UPGRADE INJECTOR BEING OFFERED FOR THESE ENGINES. THE REASON WHY I REBUILD INJECTORS INSTEAD OF SELLING NEW INJECTORS IS THAT NEW INJECTORS WILL LOSE 200 PSI OF OPENING PRESSURE WITHIN THE FIRST COUPLE THOUSAND MILES AS THE SPRINGS BREAK IN, BUT NOT ALL THE INJECTORS WILL LOSE THE SAME AMOUNT OF PRESSURE, WHICH WILL CAUSE A PRESSURE VARIANCE FROM INJECTOR TO INJECTOR. REBUILT INJECTORS STAY AT THE PRESSURE THEY ARE SET AT, BECAUSE THE SPRINGS ARE ALREADY BROKEN IN. THAT RESULTS IN A SMOOTHER RUNNING ENGINE. I ALSO PERFORM OTHER MODIFICATIONS TO THESE INJECTORS THAT RESULT IN A LOT LESS STRESS BEING PUT ON THE INJECTION PUMP. THESE INJECTORS WILL ALSO INJECT FUEL INTO THE CYLINDERS QUICKER THAN STOCK INJECTORS OR ANY OTHER COMPARABLE PERFORMANCE INJECTORS."
Anybody gotten these? Sounds too good to be true. And whats the deal with new springs vs used springs? Never heard that before either.
Old May 14, 2007 | 07:24 AM
Ace's Avatar
Ace
The spring theory sounds good, but that's about all I can make of it.
Old May 14, 2007 | 07:39 AM
XLR8R's Avatar
OK Don M - what do you have to say?
Old May 14, 2007 | 09:38 AM
dpuckett's Avatar
I sent the guy an email, but never got a response. Since I didnt have the cash on hand to buy any, I didnt call, either. I'm curious what his internal injector modifications are.
I will agree with the spring pressures- the only NEW set of sticks I ever got had lower pop pressure within 4mo. DonM redid them, but it seemed like it was a hassle for him, and even after the clean and reset, they werent as good as stock.
The black carbon on the tip of the injector is normal and means absolutely nothing. The only way to test it is on a test stand. If the parts truck injectors have the same number of holes, I dont see why you cant run it. But the line-crack method is about as poor a method as I can think of for finding a bad injector. Not to say you cant find a REALLY bad injector, but you can also get a lot of "good" injectors that actually arent.
Daniel
Old May 14, 2007 | 10:09 AM
dieselJon's Avatar
100% positive feedback. I read some and someone said it is better than marine injectors. Hmmm, somebody have any cash "laying around"?
Jon
Old May 15, 2007 | 05:25 AM
KRB's Avatar
KRB
So do all new injectors get weak and erratic after a few months? I don't see how that could be the norm, but then again, thats why I'm posting questions here .
I chickened out and 3 dayed a set of 190s from PDR yesterday. Plus a gov spring ...
Old May 15, 2007 | 08:21 AM
dieselJon's Avatar
Better go to the DTR store and get some man-sized diapers You are gonna need it when you first drive that thing with those mods
Jon
Old May 15, 2007 | 10:57 AM
dpuckett's Avatar
My own experience with marine injectors isnt real great, and wouldnt take much to be better than marine injectors.
DP
Old May 15, 2007 | 08:30 PM
KRB's Avatar
KRB
Jon
I'll let you know this weekend!
They should arrive tomorrow. I'll install 'em Friday and then haul a load of cows.
Puckett, are you saying that the 190s are marine injectors?
Old May 20, 2007 | 05:32 AM
KRB's Avatar
KRB
Swapped in the 190s. Real easy with Pred's homemade puller. Seems to run quiter now? I backed off the smoke screw a little. RPMs went down about 50, which I don't really understand.
Only problem is I have two intectors that still weep a little at the line connection. Any tricks to stopping that? The directions from PDR say not to just keep tightening but to remove line and start again which I've done several times already.
Once I'm used to these injectors I'll do the gov spring!
