Injector Gasket Part Number
I'm assuming that you're talking about the copper gasket for the fuel return line from the injector? If so it is Dodge part number 4429380. List is $5.78 (EACH!!!!) so I'd get it from cummins because they're probably cheaper. The dodge guy hooked me up for only $3.50 each which is still a massive rip off.
Ask a pump shop for a Cummins B&C injector install kit. That will get you 18 washers (3 different thicknesses), the return banjo seals, and the rubbers to keep crud out from between the injector bodies and the nuts. Should cost around $12.
Scotty
Mar 11, 2011 10:24 AM
blackfordd
May 4, 2010 03:30 PM
TxDiesel007
Feb 12, 2007 01:00 PM
