Injection pump woes
Old Oct 15, 2011 | 12:54 PM
bulltamer's Avatar
Injection pump woes
Ok I got a problem, I think my IP is on the way and fast
Idles down low when warmed up and hesitates on the top end and just don't smoke it used To Like it's not gettin enough fuel
Old Oct 15, 2011 | 02:43 PM
Rick 12v CTD's Avatar
first thing ya should do is check the fuel pressure. Could be a lift pump.
Old Oct 15, 2011 | 03:07 PM
bulltamer's Avatar
Where can I tap in for the pressure and if it is the lift pump will it hurt to run it any longer with it being bad?
Old Oct 15, 2011 | 06:21 PM
BC847's Avatar
1st Generation Admin
Just so it's been asked, when was the last time you replaced the fuel filter?
Old Oct 17, 2011 | 12:16 AM
^^ also a good question. and if you haven't changed it in a while you should be able to get a new one for like $10 and who knows, maybe it'll help fix your problem.
And if the IP isn't getting sufficient fuel I wouldn't wanna run it. It could seize
As for a place to tap in, I know my trucks banjo bolt on the filter side of the feed line post fuel filter had a 1/8 npt plug on it to check pressure. I'm not sure if that's a OE banjo bolt or if one of the POs had that put on there... but in any case that's a good spot as any to check the pressure.
tommurray
Feb 23, 2014 10:38 AM
fireram
Feb 10, 2012 11:41 AM
Zee
Apr 8, 2010 05:03 PM
jnck
Apr 7, 2005 10:43 AM
Driller
62
Mar 19, 2005 01:12 PM
