Indiana Diesel Expert Needed
Old Feb 16, 2006 | 04:11 PM
fearthedeere's Avatar
Well im home for the weekend again, and went out and started my truck, it knocks like crazy, white/blue/gray smokes all the time. Does anyone think they could diagnoise it over the phone? Or any local guys wanna swing by and help me out?
any help is great
Old Feb 16, 2006 | 05:59 PM
Javahjoeo's Avatar
Diesel help in Indiana
Check the fuel filter for water. And may have water in the fuel lines. My diesel tractor did the same thing. javahjoeo from Kokomo
Old Feb 16, 2006 | 08:17 PM
bgilbert's Avatar
Grid heater hooked up? No other changes done while the head was off, such as tune or adjust the fuel pump?
Cummins book say: Engine noise excessive- combustion knocks- a)cold starting aid malfun, b)fuel grade is not correct or quality is poor, c)AIR IN FUEL SYSTEM, d)coolant temp above spec, e)injector malfun, f)overhead adjustments not correct.
Engine runs rough at idle- a)engine is cold, b)idle speed is too low, c)engine mounts worn/loose, d)fuel leak, e)AIR IN FUEL SYSTEM, f)fuel filter or inlet restriction, g)fuel transfer pump malfun, h)injection pump timing not correct, i)valves are not sealing correctly, j)engine compression low, k)injector malfun, l)fuel injection pump malfun.
You notice Cummins puts the injectors down low in the problem diagnosis. Your buddy thinks they are the problem, I would say not. You did remove them prior to pulling the head- ie no damage to the tips? Only one sealing washer of same size under each injector?
Old Feb 17, 2006 | 12:11 PM
only change was smaller injector washers. im gonna turn my fuel down a bit and try that, i just bleed the injectors, i had my brother start the truck, and i cracked them open one at a time it cleaned up some of the roughness. im gonna change my oil again and what not.
JBOND
Mar 27, 2009 10:36 PM
PourinDiesel
Competition / Pulls / OffRoad
Jul 21, 2007 12:42 PM
SIXSLUG
Feb 18, 2007 10:00 PM
t_george77
Nov 29, 2006 06:32 PM
Hammered Scout
Aug 11, 2006 08:44 PM
