I am a new member just got my cummins
Old Oct 20, 2008 | 08:39 PM
ilovemy12valve's Avatar
Ok I just bought my 92 w250 and I installed pyro and boost gauge today. What should I be reading on the boost gauge... and what about the pyro. The highest boost I have seen is 13psi. thanks for the comments
Old Oct 20, 2008 | 08:54 PM
98whitelightnin's Avatar
Welcome to the site. Did you put the pyro probe before or after the turbo?
Old Oct 20, 2008 | 09:39 PM
Welcome. check out the sticky at the top of the board. Here you will find common articles/problems and most of all FREE PERFORMANCE . I'd say 1000 degrees wide open throttle with the lag master exhuast housing. I'm not sure about boost.
Old Oct 21, 2008 | 01:03 PM
Tuckerdee's Avatar
My stock config. ran about 14psi and 1100*. But that was at high altitude. So your EGT will most likely be lower since you're pushing some thicker air through.
Just with a 16cm housing and some tweeks with the pump I'm now running a max of about 26psi. The temps get toasty, 1300*, at high altitude with that boost.
Old Oct 21, 2008 | 02:10 PM
Evil Ram's Avatar
welcome, my truck bone stock made about 15psi of boost. Dont know what to tell you about the pyro i still dont have one myself!
Old Oct 21, 2008 | 03:01 PM
Yreka's Avatar
What would cause a stock truck to run around 28-30psi ? I believe I have a stock 21cm housing, but the prior owner "tweeked" the pump a bit.. Other than that, the truck is stock I believe. Would the pump bump cause such an increase in boost ?
Edit, looks like the boost gauge is plumbed into the intake horn.
Old Oct 21, 2008 | 03:05 PM
Tuckerdee's Avatar
Yep. Turning in the full power screw and adjusting the fuel pin would likely make that sort of boost.
Old Oct 21, 2008 | 03:09 PM
pwrtripls1's Avatar
retarded timing also runs higher boost but makes less power. Also EGT's will be higher.
Advance your pump timing and crank that fuel screw, from there you'll be hooked and looking for more power. lol
Old Oct 21, 2008 | 03:17 PM
Evil Ram's Avatar
Depending on how much the pump is tweeked YES it is possible. I went from 14-15psi stock to 27-28psi with 2turns on the power screw & 16cm
Old Oct 21, 2008 | 05:10 PM
AFC adjustments help boost numbers. fuel pin and star wheel etc. etc. just keep tweakin! LOL
Old Oct 21, 2008 | 07:28 PM
my pyro
I put it after the turbo...
Old Oct 21, 2008 | 07:32 PM
Sticky?
I am new and I dont know what a sticky is... thanks for the post
Old Oct 21, 2008 | 07:33 PM
thanks for all the post guys
Old Oct 21, 2008 | 08:59 PM
921stgen's Avatar
ilovemy12valve, push the back arrow at the top of this page and go to top of the threads that have been posted and is says "How do I ...?" look here first! AKA "The STICKY". Lots of good info about 1stgens.
Old Oct 21, 2008 | 09:07 PM
RumbleFish's Avatar
click this. this is the same link at the op of the 1st gen page, "stickied" to the top of the forum
https://www.dieseltruckresource.com/...d.php?t=102027
