I am looking for isspro tach instructions
Old Jan 3, 2008 | 07:01 AM
bigragu's Avatar
I lost mine, and going to their site does me no good w/o model #'s. I am needing word for word where 1993 oem wires connect to the special isspro tachometer harness. If anyone can link me to the installation instructions to isspro's site or scan their istructions and send them to me, I would appreciate it.
Old Jan 3, 2008 | 07:43 AM
12valve@heart's Avatar
Without knowing what tach you have, try this and see if it points you in the right direction.
http://www.egauges.com/pdf/Isspro/IS128.pdf
On Edit - Still haven't found the the '92-'93 pin out that you need. Isspro shows instructions for all gauges but doesn't list them for the R5501 (the model that I'm guessing you have). Strange.
Old Jan 3, 2008 | 04:52 PM
BC847's Avatar
1st Generation Admin
The OEM factory tachometer plug offers the following:
- 18ga Black = +12vdc for gage lights
- 20ga Orange = 12vdc Common
- 18ga Red = Switched +12vdc
- 20ga Grey w/light blue tracer = Tachometer Signal From PCM
Originally Posted by BC847
NOTE: If you're gonna run the ISSPRO gage that I have, do not waste your money on the ISSPRO adapter. To start with, the included instruction is backward in that it directs one to connect the 2 1/16" gage to the adapters white wire. As such the built-in filter component of the adapter is placed in the signal circuit.
Wired as such, the gage WILL NOT function.
The correct wiring has you connect the yellow wire which equates to a direct connection from the trucks PCM to the gage.
As such, the adapter amounts to an expensive 3' piece of four conductor wire with individual connectors on one end (NO molded plug for the OEM connector under the dash as some might think).
Save your money and use your own wire and connectors from Radio Shack.
As found here ~ https://www.dieseltruckresource.com/...d.php?t=173561
Old Jan 5, 2008 | 04:55 AM
KRB's Avatar
KRB
Let me know if you are still stumped and I'll go hunt mine up.
Old Jan 7, 2008 | 01:35 AM
bigragu's Avatar
Guys, thanks a plenty. I used the links to get Isspro's phone number and tech support emailed me all the directions, including a CAD design sheet to manufacture the harness for the tach to tie into the OEM plug. Thanks again.
Old Jan 12, 2008 | 10:51 AM
MichaelP's Avatar
Sorry I didn't see this post sooner or I would have answered. Glad that you found what you were looking for, let us know if you need any more assistance.
Regards,
Michael Pliska
Old Jan 12, 2008 | 02:25 PM
MoparMarv's Avatar
The plug is to left side of the colum next to the fuse block if you haven't found it. I was just tapping in there for my boost and fuel pressure gauge lights in the pods
Power Ram 250 C
Jun 11, 2007 09:54 PM
jmccart
Mar 6, 2007 07:17 PM
csramsey640
Sep 13, 2005 01:00 PM
'80Toad
Apr 10, 2005 03:47 PM
