HTT Stage III boost?
Old Aug 21, 2005 | 03:42 PM
rockjeep73's Avatar
I've got an HTT Stage III HX35 on my first gen, I was wondering how much boost I could pull out of the thing before it gets out of its efficient range and starts over-heating the air?
Saying that a stock HX35 is good until 35psi, and a HX40 is good for 40psi, I figured that it should pump out a cool 40psi since its basically an hx40 compressor.
Correct me if im wrong.
Old Aug 21, 2005 | 04:52 PM
Where did you hear that an HX-40 is "good" to 40 psi? Even the modified Holset compressors (HTT, PDR) are all pretty much done by 38 psi.
The benefit that an HX-40 gives you over an HX-35 or H1C based hybrid is more exhaust flow, not more boost.
Old Aug 21, 2005 | 04:53 PM
ChrisLib's Avatar
Sounds about right. I have a dodgezilla wich they say is good for around 40/42 psi, and both turbos are very similar (35/40 hybrids). My 35 psi boost gauge will bury itself so I guess it`s capable of making somewhere around that.
Old Aug 21, 2005 | 05:48 PM
swank's Avatar
high tech says: do NOT go over 38 psi. it might even be 36. i can't remember. you should give them a call.
Old Aug 21, 2005 | 07:02 PM
bmoeller's Avatar
My PDR 40 is set at 38#, but I guess they are cutting back to 32, to prevent shaft breakage.
acook
Apr 11, 2006 12:44 AM
SSweeney
Jan 17, 2006 05:20 PM
mhuppertz
Sep 17, 2005 05:15 PM
Monty
Dec 24, 2004 11:50 AM
bwat4
Dec 15, 2004 05:08 PM
