How much transmission fluid?
Old Oct 14, 2006 | 04:01 PM
boiler-rat's Avatar
Ok, I got the tranny line fixed. Cut it off and put on a flare fitting. Ok so far.
Next question. How much fluid do these trannys hold? I put 1 qt. in torque convertor before installing. Then I added 4 qts. before cranking. Cranked in park and added 5 more qts while running. ( 10 so far)
With brake on, shifted thru gears. Barely could feel it changing. Checked level in neutral, not touching stick. Added one more qt and now just barely touching stick. Starting to shift firmer. Waiting on wife to get home to go get more. I thought it held 10 qts. Wuzzup???
Old Oct 14, 2006 | 06:47 PM
My book says 10.5 qt. if you drop the pan. Pulling the converter loses you several more quarts, I wouldn't be surprised if it takes another 2 qt.
Old Oct 14, 2006 | 06:57 PM
boiler-rat's Avatar
I had a new converter plus flushed and blew out all the lines. It took 15 qts.!!
phatboy
Nov 23, 2008 11:18 AM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
Hoss
Sep 10, 2006 02:13 AM
RobG
Aug 18, 2005 01:22 PM
