How Much Boost ??
Old Dec 2, 2005 | 06:03 PM
BearKiller's Avatar
How Much Boost ??
How many psi of boost will an 89 model 1st Gen. un-modified produce??
The combination pyrometer/boost gauge that is in my truck reads to 20psi boost.
The gauge is Hypermax brand.
If I plumb the boost side of this gauge into the intake manifold and boost exceeds 20 psi, will it mess up my gauge or just peg the needle??
Old Dec 2, 2005 | 06:06 PM
BC847's Avatar
1st Generation Admin
18psig.
As found here: http://dodgeram.org/tech/dsl/Facts/91specs.html
Old Dec 2, 2005 | 06:07 PM
You should only get 15-18 psi.
Most gauges will handle a little overload without problems, but if you plan to turn that truck up at all you need at least a 35 psi gauge.
Old Dec 2, 2005 | 06:48 PM
bgilbert's Avatar
FWIW, one is only wasting money if buying a less than 40psi boost gauge. On a non-intercooled truck that might get turned up in the future, a 60psi will be necessary. You will be pegging the 40psi gauge.
Old Dec 2, 2005 | 06:50 PM
bgilbert's Avatar
I would use that gauge to monitor fuel pressure instead of boost. 20psi is a good one for fuel pressure. Then buy a 40psi gauge at the minimum.
Old Dec 2, 2005 | 07:27 PM
BearKiller's Avatar
I thought a fuel pressure gauge measured vacuum and pressure.
Old Dec 2, 2005 | 07:37 PM
Only if you have a really weak lift pump.
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
MDMIKE
Jan 18, 2005 10:02 PM
NeedMoPower
Jul 12, 2004 10:04 AM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
