how much boost?
With the mods in my sig, my truck runs about 39lbs until I run out of gear (about 65mph's). Then it drops off and holds about 31lbs screaming it's head off. I don't know much about any other injectors, but when I put the POD's in it made the biggest difference. I don't really care for the idle haze, but I did gain mpg's and quite a bit of power for $200 (got them used). Another thing that gained some PSI was the cannon of an air intake I made.
With my stock injectors turned up I and around 22psi with both an 18.5 and a 16cm housing with the A518 and the 47RH I put in.
Changed to POD's and the boost jumped to 30 something. Went to a WH1C with a 12 waste gated, set at 38psi, then to a HTT stage IV compressor again gated at 38psi.
Changed to a S300 62/65/12, gate is factory set at 40psi and I was pushing about 38-39psi.
Went to EDM's 6x16's. Now with a PS intercooler and 3" tubes I'm pushing 45ish for boost.
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
