How does the ksb work?
Old Dec 7, 2005 | 05:34 PM
Underpsi's Avatar
Title says it all, I just wanna know how it works. I know it retards the timing.
Old Dec 8, 2005 | 01:45 AM
bgilbert's Avatar
Retards the timing on non-intercooled pumps, advances it on intercooled pumps.
Old Dec 8, 2005 | 10:44 AM
Underpsi's Avatar
anyone know how?
Old Dec 8, 2005 | 01:02 PM
Alec's Avatar
I'm posting a write-up and diagram in my photo gallery. As soon as it is approved I'll add the link.
In short, either device raises the internal pump pressure at lower engine speeds, thus advancing the pump timing.
Old Dec 8, 2005 | 08:19 PM
6DoubleDuece's Avatar
How about what is it?
Thanks,
Brenden
Old Dec 8, 2005 | 08:24 PM
G1625S's Avatar
Thanks,
Brenden
Like Alec said, it's a device that, under certain conditions (usually cold ones) will allow/encourage higher internal pump pressure. This higher pressure advances the injection timing. When the engine is very cold, advanced timing helps the engine run smoother.
Old Dec 8, 2005 | 09:32 PM
Underpsi's Avatar
isn't retarded timing smoother in cold weather? and thats why some people are worried about having trouble starting thier trucks in the cold if they advance the timing
Old Dec 9, 2005 | 12:16 PM
Alec's Avatar
Old Dec 9, 2005 | 12:25 PM
Alec's Avatar
This write-up describes a system using a wax motor similar to the old trucks. The newer trucks use a solenoid. Either system raises the internal pump pressure at lower engine speeds.
As for timing and starting: When the engine first starts, the timing is fully retarded, because there is no pressure built up inside the pump housing. This makes it easier to spin the engine over, and get the engine up to operating rpms. Once the engine is spinning at the minimum cranking speed for starting (which is normally around 500 rpm for a diesel), advancing the timing makes the engine run better, because more heat is captured in the compression stroke, and the combustion chamber temperature goes up, etc. With the VE pump this happens, because the internal pump pressure rises, and actuates the variable timing mechanism.
If you advance the static timing, it makes it harder for the starter to crank the engine over, but will actually improve things once the engine has started.
Old Dec 9, 2005 | 02:21 PM
G1625S's Avatar
Thanks Alec, well said.
Old Dec 9, 2005 | 08:03 PM
Thanks for the explanation.
Brenden
Old Dec 11, 2005 | 12:20 PM
Underpsi's Avatar
Thanks I appreciate it
Old Dec 12, 2005 | 12:29 PM
Alec's Avatar
I'm happy if it was helpful.
Timing is a big part of getting a lot of fuel to burn (and thus generate big HP) aparently. I am more familiar with it as an efficiency/longevity problem: advanced timing improves efficiency but tends to reduce longevity.
92smokin blacky
Jul 17, 2012 01:33 AM
skahla
Nov 20, 2009 08:13 AM
BRUISER
Jan 18, 2009 02:28 PM
SPINPOSI
Mar 29, 2007 05:52 PM
59FORD
Feb 26, 2007 06:44 AM
