Help! Truck won't start
I figured I'd ask you guys before I start replacing parts on the truck. The truck I'm talking about is the 90 in my signature. It has a starting problem of some sort, but I'm not sure what the problem is. When I go out to start the truck most of the time it will start fine, but every now and then it is just totally dead, all of the lights work so I know its not the battery when I hit the key to start it all I hear is a click. An hour or two later the truck will start and run fine, I thought something might be getting hot and not working right so I drove the truck around for about 30 minutes to get everything warm and then I shut it off and it started fine like 5 times, but the next time I drove it it was back to just a simple click, like a relay clicking or something and once again I let it set for a little while and it starts fine. I would think if it is something getting hot that it would do it every time you try to start the truck when its hot, but most of the time it works fine but it is getting annoying when it won't start and I want to get it fixed before I get out somewhere and it won't start and I have to tow it home. Any help on this would be great, I'm going to start tearing into it this weekend I think, but if anyone has ever had this happen to them or could at least point me in the right direction it would be great. I don't think it is the starter because it will start sometimes and it cranks fine, but other times it is just totally dead.
Thanks All
Thanks All
Thanks All
Thanks All
i vote for the contact thingies in the starter. always good to check all cables and each end before spending money. brothers 96 just did this two weeks ago and a rebuilt starter fixed it.
An Auto tranny equipped vehicle will have a "neutral start switfch" which prevent sthe truck from starting in gear. These are generally located on teh steering column controlled by a rod from teh gear selector, or located on teh outside of the tranny housing controlled electronically. I think the Dodges are on teh column, but not certain. these are plastic switches and can wear, causeing intermittant contact, creating a start problem. This is what Trebor was getting at by jiggiling the gear selector. ALso, next time it wont start, try shifting to nutreal and starting the truck..this is the best way o fpin-pointing the switch as the problem.
If it is not the n-safety switch, then you are looking at rebuilding the starter.
DOnt forget your starter relay, or the wiring from the battery to the starter solenoid. try the plug in next to the battery with the brown and pink wires. Jup these two and see if it starts. I have had 2 starters that were just gunpowder looking inside, and contacts would have not helped them.
Daniel
Daniel
I too vote for something in the starter. It starts sometimes because of the position that its in. The next time it might not start due to the starter thingy being in the bad position. I dont know the technical term for it, I just know how it does what it does
if that makes any sense? I usually dont, I speak the Ron White language
Subliminal
Dec 15, 2010 04:35 PM
Machinos
Mar 16, 2008 01:34 AM
